iam new to raspberry pi and i got an error while a running servo motor in my object detection script i need to run the servo whenever my if condition is true so the same pin run multiple times if condition satisfies i have done giving servoPIN = 22 GPIO.setmode(GPIO.BCM) GPIO.setup(servoPIN, GPIO.OUT) out of the for loop but doesn't work
Here is the part of the code all import functions are given on top of code(full script :https://github.com/aswinr22/waste-model/blob/master/picamera1.py)
for i in range (classes.size):
    if(classes[0][i] == 2 and scores[0][i]>0.5):
      servoPIN = 22
      p = GPIO.PWM(servoPIN, 50)  #this line shows the error
      p.start(2.5) # Initialization
      try:
        p.ChangeDutyCycle(5)
        time.sleep(4)
        p.ChangeDutyCycle(10)
        time.sleep(4)
      except KeyboardInterrupt:
        p.stop()
      except:
          #print ("exception")
    GPIO.cleanup()
output:(motor turns on and immediately showing below error)
  File "Object_detection_picamera.py", line 150, in <module>
    p = GPIO.PWM(servoPIN, 50) # GPIO 17 for PWM with 50Hz
RuntimeError: A PWM object already exists for this GPIO channel
I dont know why this happening please help me
rah
For loop to move servo BCM mode GPIO pin #22 does not work. Why?
Short Answer
Well, I think you are using the wrong pin. BCM GPIO Pin #22 cannot do PWM. See the chart in the long answer below.
Long Answer
I suggest to first write the following little test function.
 def sequentialMoveServo(positionList)
    for position in positionList
       if (position > 0) AND (position < 180)
           moveServo(position)
       else
           pass
    return
Then we can the function like below:
sequentialMoveServo([+30, +45, -20, +180, +230])
The servo should move sequentially to the positions as below:
30, 45, and 150 degrees, skipping -20 and +230 degrees
Servo research notes
I read the tutorial "Raspberry Pi Servo Motor Control" and find everything OK. The tutorial uses the TowerPro MG996R servo. I remember I also used the same servo a couple of years ago, using Arduino. I am going to search my junk box to find one.
I luckily found one MG996R. I then skimmed the datasheet and find it OK. I moved to tutorials by SparkFun, SourceForge, and Electronic Wing, and found them good. The AdaFruit's tutorials as usual are for Arduino guys. So I skipped Lady Ada, ...
I found ElectronicWing's picture on PWM pins assignment very good. So I borrowed them and pasted here.
servo picture
I found Rpi ahs 4 PWM pins. I decided to use Pin 18 to test the water. Below is the hardware setup.
servo motor hardware setup
Now I have debugged a python program to do the following.
  1. Set GPIO pin 18 high for 2 seconds, to switch on Blue LED to full brightness.
  2. Set the same GPIO pin 18 to output PWM of 1kHz, 50% duty cycle, to switch on/off Blue LED to result half brightness.
# Servo_test32 tlfong01 2019may12hkt1506 ***
# Raspbian stretch 2019apr08, Python 3.5.3
import RPi.GPIO as GPIO
from time import sleep
# *** GPIO Housekeeping Functions ***
def setupGpio():
    GPIO.setwarnings(False)
    return
def cleanupGpio():
    GPIO.cleanup()
    return
# *** GPIO Input/Output Mode Setup and High/Low Level Output ***
def setGpioPinLowLevel(gpioPinNum):
    lowLevel = 0
    GPIO.output(gpioPinNum, lowLevel)
    return
def setGpioPinHighLevel(gpioPinNum):
    highLevel = 1
    GPIO.output(gpioPinNum, highLevel)
    return
def setGpioPinOutputMode(gpioPinNum):
    GPIO.setup(gpioPinNum, GPIO.OUT)
    return
# *** GPIO PWM Mode Setup and PWM Output ***
def setGpioPinPwmMode(gpioPinNum, frequency):
    pwmPinObject = GPIO.PWM(gpioPinNum, frequency)
    return pwmPinObject
def pwmPinChangeFrequency(pwmPinObject, frequency):
    pwmPinObject.ChangeFrequency(frequency)
    return
def pwmPinChangeDutyCycle(pwmPinObject, dutyCycle):
    pwmPinObject.ChangeDutyCycle(dutyCycle)
    return
def pwmPinStart(pwmPinObject):
    initDutyCycle = 50
    pwmPinObject.start(initDutyCycle)
    return
def pwmPinStop(pwmPinObject):
    pwmPinObject.stop()
    return
# *** Test Functions ***
def setHighLevelGpioPin18():
    print('  Begin setHighLevelGpioPin18, ...')
    gpioPinNum   = 18
    sleepSeconds =  2
    setupGpio()
    sleep(sleepSeconds)
    cleanupGpio()
    print('  End setHighLevelGpioPin18, ...\r\n')
    return
def setPwmModeGpioPin18():
    print('  Begin setPwmModeGpioPin18, ...')
    gpioPinNum   =   18
    sleepSeconds =   10
    frequency    = 1000
    dutyCycle    =   50
    setupGpio()
    pwmPinObject = setGpioPinPwmMode(gpioPinNum, frequency)
    sleep(sleepSeconds)
    pwmPinObject.stop()
    cleanupGpio()
    print('  End   setPwmModeGpioPin18, ...\r\n')
    return
# *** Main ***
print('Begin testing, ...\r\n')
print('End   testing.')
# *** End of program ***
Sample Output - 2019may12hkt1319
 RESTART: /home/pi/Python Programs/Python_Programs/test1198/servo_test31_2019may1201.py
Begin testing, ...
End   testing.
The blue LED switch on full and half bright. So far so good. I am going to use a scope to check out if the PWM waveform is clean and sharp.
Ah, Sunday afternoon tea time, see you later, ... :)
Now I am checking out the timing requirements of the servo. servo timing
Now I know that the timing for servo to move to middle position is 50Hz, 7%, 1.4mS. So I wrote the test function below, and checked the output.
def servoPwmBasicTimingTestGpioPin18():
    print('  Begin servoPwmBasicTimingTestGpioPin18, ...')
    gpioPinNum         =   18
    sleepSeconds       =  120
    frequency          =   50
    dutyCycle          =    7
    setupGpio()
    sleep(sleepSeconds)
    pwmPinObject.stop()
    cleanupGpio()
    print('  End   servoPwmBasicTimingTestGpioPin18, ...\r\n')
    return
Pin18 PWM output looks good.
servo timing 03
Now I can implement the following condition/action table
Condition Action Table
  1. Middle condition = servo moves to Middle action
  2. Leftmost = servo moves to LeftMost action
  3. RightMost condition = servo moves to RightMost action
I have written a little program to loop the above conditions, as show in the following youTube.
Condition Servo Action Program YouTube Demo
/ servo research notes to continue, ...
Raspberry Pi Servo Motor control - Rpi Tutorials
Servo MG996R Datasheet - TowerPro
Python (RPi.GPIO) API - SparkFun
Using PWM in RPi.GPIO - SourceForge
Raspberry Pi PWM Generation using Python and C - ElectronicWing
Servo Tutorial - Lady Ada
PWM Tutorial - Lady Ada
Servo Motors Using Arduino - AdaFruit
The script appears to be initialising PWM on the same pin multiple times in the for loop.
Do the p = GPIO.PWM(servoPIN, 50) just once in the script.
joan
  • 71,852
  • 76
  • 108
