I am using the power MOSFET IRF504N. I am not sure if my Rpi's GPIO 3V3 signal can directly input to the gate of the MOSFET which requires 4V minimum.
I guess that I don't need a gate driver to shift up the Rpi's 3V3 signal. So I am now experimenting, ...
I read the IRF540N datasheet which says Vgs(th) is 2V minimum and 4V maximum. Does it mean Vgs between 2V to 4V won't guarantee anything?
I forgot to mention that the motor is DC12V 100mA (37GB528-70 70rpm). And I also want to drive another solenoid valve DC12V 300mA (FDZ-5). The picture below shows the two little guys.
Motor and Solenoid Valve Picture
schematic
This might work, but it won't work well.
The parameter you've asked about (Vgs(th) is 2V minimum and 4V maximum) means this:
The threshold voltage at which conduction begins from Drain to Source is a minimum of 2 V, and a maximum of 4 volts. Since the RPi GPIO is 3.3 V, there will be some devices that may not conduct at all. See Fig 3 in this spec sheet.
Bottom Line: You need to drive your chosen MOSFET with a much higher voltage than the 3.3 V available from the RPi GPIO pin if you want your circuit to operate "properly" (within design specifications). You should have around 7 V gate-source voltage for best results - at least for this MOSFET.
Seamus
  • 23,558
  • 83
OP asks if Rpi 3V GPIO signal can trigger the N-channel power MOSFET IRF540N with trigger threshold >4V to drive (a) 12VDC 35mA motor, (b) 12VDC 250mA solenoid.
A short answer is that RPi's 3V GIPO high signal can likely trigger and slightly turn on the IRF540N's channel to barely pass through <50mA and therefore can slowly move a 35mA DC motor. However the barely opened channel with high Rds on resistance does not allow enough current to drive a >100mA solenoid.
There is a get around - use a 3V/5V logical level trigger alternative such as IRL540N.
Rpi 3V GPIO triggers IRF540N to drive 35mA DC motor
(1) AN11158 Application Note Understanding power MOSFET data sheet parameters - Rev. 6.0 — 2020jul06
