i am running a low side switch with the 3.3V gpio output of the pi, and for the particular transistor i’m using (irf520 ) the 3.3V is barely enough to turn it on - is there some clever positive feedback i can use to force the transistor ‘very on’ when on and off when off?
How abt this, I put the gpio into high-impedance input mode to turn transistor on, and set output=0 to turn transistor off. current into gpio pin when output=0 is 1.2mA which i suppose is ok. Is 12V after 10Kohms ok on a raspi input pin?
schematic
jeremy_rutman
Firstly you are applying 6V to the GPIO and are likely to damage the Pi.
There is nothing you can do to make a MOSFET which needs more than 3.3V miraculously work. Although you could use a transistor to drive the gate.
There ARE MOSFETs which switch with 3.3V Vgs although most need more.
You have to drive this MOSFET with another transistor(a BJT perhaps). Or you could replace the MOSFET with a BJT. The are good for driving transistors.
Sohan Arafat
  • 1,852
  • 43
Your schematic is not a good idea: It will put 6V on your GPIO pin, and fry your RPi. You could save yourself some money by avoiding the obvious mistakes :)
The best solution for driving a MOSFET from your 3.3V GPIO is a Darlington Pair. Here's why I say this.
If you want to drive an n-channel MOSFET as you've shown in your schematic, simply swap the npn Darlington device in this answer for a pnp Darlington. Similarly, you could use the npn Darlington to drive a high-side p-channel MOSFET.
I'll stop here. If you're interested in this approach, mod your question & post a comment here. I'll try to help.
Seamus
  • 23,558
  • 83
