30
I'm trying to decide what is the best option for powering a Pi4. The specs mention for a minimum of 3A. Let's consider we would also like to connect a 2.5" drive to the Pi4. Could someone more experienced with power supplies help me with the following?
  • How far can we go with a good 2.4A USB charger?
  • The official power supply is rated 5.1V/3A. Does this mean that this may turn out to be inadequate?
  • Some 3rd party chargers (e.g. the one discussed here) are rated for 3A in Quick Charge mode. Will the QC mode be activated with RPi4? Or the charger will operate as a regular 2.4A charger?
  • How can we tell apart 3rd party chargers that would work with RPi4? Are there any of them? I've seen a couple of models mentioning 5V/4.4A output. But I'm afraid this is only the aggregate amperage (they were multi-port USB chargers).
m000
  • 483
6 Answers6
11
Use a PoE Hat:
Third-party USB-C charging devices can be cheaply wired, potentially destroying connected devices as well as starting fires. A safer alternative is to power your Pi using PoE which beyond reducing these risks, offer additional benefits:
Benefits:
Using a PoE Hat is easy to setup and enables you to:
Additional Requirements:
In addition to a PoE Hat, you'll require a PoE switch and some decent Ethernet cables. Some suggestions for which I've had great results with my own PoE Hat use are:
Cost Comparison: Mains vs PoE: Total cost of a PoE Hat + 5 ft Tripp Cat6 24 AWG Ethernet cable = £20, versus £8/each for a "official" (genuine; not third-party) Raspberry Pi USB-C mains power supply unit. But for the £12 difference the additional benefits described above I feel are worth the small premium.
Pi 4 Compatibility: Haven't myself yet been able to get a Pi 4 (vendors I tried were out of stock unsurprisingly) but found this link to a Register article about the Pi 4 which notes the PoE Hat IS compatible in their report on the new Pi
F1Linux
  • 1,677
The best option is a good quality power supply, as cheap brands may say they are rated at 2.4 amps, when they don't actually supply that much. Based on the numerous bad experiences i've had with 3rd party chargers, i'd highly recommend buying the official one from the foundation!
Whether that is adequate for the hard drive is another question. I haven't tried the Pi 4 yet, but my 3B actually worked fine (with no low-voltage warning) with a 1A USB hard drive plugged into it. The adapter powering the Pi was rated at 2.1A.
nikodean2
  • 180
The spec specifically states that:
A good quality 2.5A power supply can be used if downstream USB peripherals consume less than 500mA in total.
Using a 2.4A power supply with the Pi 4 and a 2.5" HDD is going to be borderline assuming a typical power rating of the 2.5" drive of about 1.8W to 2.7W (see here). From the above statement - after all it really says that the Pi will need just 2A - the official supply should however work.
According to this answer Quickcharge modes are likely not going to help.
Ghanima
  • 15,958
  • 65
You can either rely on reviews or ask the seller and take their word for it, or you can get the supply, test it, and return it back if it doesn't perform. Obviously, in the latter case you'll want to buy it from a place where you can return it for free.
There is no way to tell from the labels how much current a power supply can really deliver. I've seen 2.5 A chargers which go down to 4V at nominal current. Good enough to charge a phone, not nearly good enough for a voltage-sensitive device such as an RPi.
One place which (surprisingly) sells very decent cheap 5V PSUs is IKEA. They offer a 3-port charger with 3.4A total current, 2.4A per port, which really holds its promises. If you need lots of power, plugging the RPi in one port and a powered hub in another gives you a combined power of 17W.
If you want to (try to) get away with something cheap, check out this charger. It has enough power to get the RPi4 running, so if you deem a non-certified charger safe enough to use (hint: most of the cheap electronics you buy over the Internet isn't properly certified), go ahead.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
Fortunately I gathered much experience over the years. The most important with theese is how they are designed. You should never, i mean NEVER buy shady power supply from unknown chinesse sellers / ebay / aliexpress etc.! Majority of them are really badly designed. They might kill not only the device because of poor design, but also YOU because of poor high and low voltage separation. But the shady sellers don't really care, the job is done when the sale is made. Problems they usually have:
  • Insufficient high and low voltage separation. 220V lines are too very close to 5V on PCB which can cause 220V to get to the 5V line and you are dead.
  • Voltage not 5V which can kill your device. Often, when they are under load voltage starts to drop, or they emit excessive heat.
  • There is a lot of noise on the output. Voltages goes up and down from like 4V to 6V or even more. This can kill your device.
So a general advice would be to buy it from respectable manufacturer like samsungs, htc, lg, apple, and other major brands. According to tests they are generally very good.
As stated in previous comment, IKEA makes very decent USB power supply (tested). Also (you wont belive) their LADDA rechargeable AA and AAA are most likely Panasonic eneloop PRO acording to tests. So IKEA is probably a safe and good choise for power supply.
I would suggest you choose based on information on this web site, where this Danish guy makes reviews of chargers with proper tests and measurements from electrical point of view: https://lygte-info.dk/info/ChargerIndex%20UK.html
Example of good ikea charger: https://lygte-info.dk/review/USBpower%20Ikea%20Lorby%20USB%205V%203.4A%20303.877.07%20UK.html
Example of BAD and dangerous fake apple charger: https://lygte-info.dk/review/USBpower%20New%20European%20standard%205V1A%20plug%20UK.html
Also dont watch the hipsters chargers reviews on youtube, where they comment, color of cable, number of ports, etc. it is useless. You need measurements like this Danish guy does it.
1337
  • 131
I've successfully powered a Pi 3B+ using a cheap 12V 3A wall wart from aliexpress and a cheap buck converter from aliexpress. The 12V 3A provides for well above 3A when dialed down to 5.1V through the buck converter.
The most difficult part is soldering wire on to a USB plug.
https://www.aliexpress.com/item/33014935336.html
https://www.aliexpress.com/item/32798886986.html
I plan on doing the same for my Pi 4 when it arrives.
bor999
