79
I read that it's possible to allocate either 128MB, 64MB or 32MB to the Raspberry Pi's video memory.
Given that my primary use case for this machine is educational: I will be running lightweight python scripts and web-browsing. Is it likely to suffer any loss of features by switching to only 32MB of memory for me?
I do not anticipate wanting to use any 3D or playing any video.
Duncan
  • 101
Salim Fadhley
  • 2,035
I would expect you to not experience a noticeable difference unless you are doing graphically heavy tasks, such as playing video.
However, it's difficult to gauge the optimal settings, as performance limits will vary depending on what applications are executing and user expectations.
The best thing you can do is experiment.
If you do want to change the split, then there are two different methods, depending on the firmware you have. If possible then make sure you have the latest firmware. If it is not possible for you to update for whatever reason, then I have included both options below:
New Firmware (after October 2012)
  • Edit /boot/config.txt and add or edit the following line:
    gpu_mem=16
  • The value can be 16, 64, 128 or 256 and represents the amount of RAM available to the GPU.
Old Firmware (before October 2012)
In order to alter the video memory you need to replace the start.elf file on the /boot/ partition of the image. The possible .elf files should be in the /boot/ directory on your Pi. You make the switch by replacing the start.elf file with one of the others.
There are three memory models, and here are the recommendations taken from the Raspberry Pi discussion board:
  1. 224MB RAM and 32MB VRAM for a Linux desktop distro, or a heavy (non GUI) applications that don't need to play video, nor render 3D.
  2. 192MB RAM and 64MB VRAM (default) for desktop distro's that want to play video or have 3D effects.
  3. 128MB RAM and 128MB VRAM for applications and games that do extensive multimedia or play 3D rendered games.
 And one more:
240MB RAM and 16 VRAM for almost zero graphical power. There is enough GPU memory to render the screen, but not much else. Use this when you need a further non GUI performance boost.
Jivings
  • 22,656
  • 94
  • 140
53
RAM is very crucial for Linux performance for couple of reasons:
  • Caches. Linux runs without free memory for most of the time. If some memory is not used by applications, it is used for caches which speeds things up. So no memory is ever wasted. If applications needs more memory, caches are freed so caches won't ever prevent applications needing more RAM from running. But of course the more your can cache, the better.
  • Many applications (especially desktop ones) needs a lot of memory to run nowadays. This is no surprise - most desktop systems (or even smartphones) this days have a lot more memory than Rapsberry Pi. For example web browsers even lightweight) will use tens of MB of memory as soon as you open some bigger web site.
  • Each and every application needs some amount of memory. So the more applications you run, the more memory they use.
So you always want to have as much ARM memory as possible. But GPU has its own needs depending on what features you want from it.
256MB version
For older RaspberryPi, with 256 MB of RAM, 4 splits are available:
  • 240/16 - The most RAM size ARM can get (240MB) with mimial GPU memory. It's the best for general computing when you don't need 3D graphics or hardware video acceleration. It has enough memory to handle 1920x1200x16bpp framebuffer resolution. While 32bpp is also working, it's not recommended since it leaves very small amount of free memory for GPU.
  • 224/32 - This one is deprecated in favor of 240/16 split. It has 3D and hardware video decoding build in but since there is not enough memory to actually use it, there's little point in using it. Unless you have some problems with 240/16 split or want to use 32bpp framebuffer at highest resolution. It is possible it will be deleted in the future.
  • 192/64 - You need at least 64MB of GPU split to use hardware video acceleration or 3D graphics. It may not be enough GPU memory for hardware accelerated video playback at highest resolution or if you need a lot of GPU memory for things like textures.
  • 128/128 - The most RAM GPU can get. Use it when you need a lot of memory for 3D graphic card and hardware accelerated video playback in high resolution. This split is needed for RaspBMC to work properly or to play fullHD video content with omxplayer without problems.
512MB version
New versions of RaspberryPi has 512 MB of RAM. You have 4 additional splits designed for this version:
  • 496/16 and 448/64 - like 240/16 and 192/64 split for 256MB respectively but with 256MB more RAM available for ARM. Since GPU has only 16 MB/64MB or RAM, all the limitations from 240/16/192/64 still apply.
  • 384/128 - Similar to 128/128 split for 256MB - you should get all the graphic chip features but with reasonable amount of ARM memory. This will probably be the most universal split right now.
  • 256/256 - Some bonus graphic card memory if you really need it, like for big textures and similar things. While 256MB of ARM memory is bigger than you could possibly have in older RaspberryPis, I don't think this one will be used on many occasions.
Dynamic splits
New versions of firmware package removes most of start_*.elf files, leaving only start.elf and start_cd.elf (also fixup*.elf files where added). From now on, you don't have to manually choose proper start_*.file. Instead, you should use gpu_mem* options in config.txt file to choose how much memory goes to GPU. The remaining memory will be allocated to ARM. It should be possible to use arbitrary number in the following range for this options:
**512MB of RAM**: 16M-448M
**256MB of RAM**: 16M-192M
While there is no hardcoded split values right now, most of the informations for the rest of this answer should still be valid when you're trying to determine how much memory should be allocated to GPU.
start_cd.elf and fixup_cd.elf files are cutdown versions of the respective files, only used when gpu_mem=16.
Using one SD card on both 256 and 512 MB version
If you are using one SD card image for different RaspberryPi versions, you can use gpu_mem_256 and gpu_mem_512 options. First one will only be used on 256MB version while second one only on 512MB version of the board.
Krzysztof Adamski
  • 9,605
  • 38
  • 53
From my experience, 8-16MB for just terminal. 20MB for 800p GUI 24MB for 1080p GUI 32MB for 1440p GUI 64MB for <1080p youtube videos 128MB for 1080p youtube videos 256MB for 4k videos (more than likely the Pi can't do 4k very well).
ProDigit
