20
If I use the Pi a bit, filesystem corruption soon appears.
For instance, this file was changed to another one:
$ ls -alt  /etc/apt/apt.conf.d
total 16
lrwxrwxrwx 1 root root   13 Oct  2 22:18 50raspi -> ../init.d/ntp
Or /var/lib/dpkg/info/fake-hwclock.list became a binary file, which means dpkg can no longer work:
dpkg: unrecoverable fatal error, aborting:
 files list file for package 'fake-hwclock' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
fsck on the filesystem finds many mistakes and send dozens of files to lost+found:
Pass 1D: Reconciling multiply-claimed blocks
(There are 34 inodes containing multiply-claimed blocks.)
File /etc/fake-hwclock.data (inode #26, mod time Thu Aug 16 02:20:47 2012)
  has 1 multiply-claimed block(s), shared with 1 file(s):
        ... (inode #30, mod time Thu Aug 16 02:20:47 2012)
Inode 30 ref count is 1, should be 3.  Fix? yes
dmesg displays what looks like I/O errors:
[   49.082758] mmc0: final write to SD card still running
[   59.088233] mmc0: Timeout waiting for hardware interrupt - cmd12.
[   59.089411] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
I tried with four different SD cards, of makes SanDisk SDHC 16 GB and Duracell SDHC 16 GB. So, it does not seem to be the card.
I also tried with Raspbian 2012-08-16-wheezy and ArchLinux 13-06-2012. Both have the same problem so I assume it is not a bug in the OS.
Following advices by @gnibbler and @Avio, i ran memtester (which, unlike memtest86 on the PC, runs after the kernel and therefore cannot test all the RAM) and it reported no problem. "memtester 200 2" -> everything OK
Following the discussion in http://www.raspberrypi.org/phpBB3/viewtopic.php?f=29&t=6201&start=400 , I tried from a new image with a config.txt written for a little underclocking:
core_freq 240
arm_freq 650
sdram_freq 350
but it made the problem worse (a lot of timeouts on the card)
I have only one Raspberry Pi so I cannot check with another. Known problem? Broken hardware?
bortzmeyer
  • 472
It may be to soon to answer my own question but, until now, the option which was the most successful was:
over_voltage=2
Until now (it's only a few days), it seems better (no corruption or card timeout yet).
I'm not an expert in power issues so, before using this on your own Pi, please do some research.
Does it mean my Pi has a voltage problem, as suggested by @gnibbler?
bortzmeyer
  • 472
There is a really good chance that you have a problem with the RAM and, maybe, you are not experiencing kernel freezes because the Raspberry Pi's architecture is somehow tolerant to a certain degree of memory corruption.
The first thing to do is to change the memory split, reducing the video memory to the minimum, to maximize the amount of available RAM (240 MB of RAM and 16 MB of VRAM). I suggest to start over with a new raspbian, freshly copied to the SD. Then you can install and run memtester.
sudo aptitude install memtester
Here there is a small tutorial about how to launch memtester, and this is the man page. The command line should be something like:
sudo memtester 200 2
Where 200 is the amount of MB to test and 2 the number of passes. Remember that this solution works purely in userspace, so the amount of free memory is less of the amount of total available memory. If you want the exact number, type:
cat /proc/meminfo
However, given that the problem isn't in your memory cards and the Raspberry Pi is quite "monolithic", probably the only option available will be to return the Pi to your reseller.
Avio
  • 1,239
This is a long shot, but every time I run rpi-update to update the firmware the file system gets corrupted somehow such that I can no longer create an image of the SD card using dd (see my question). I first noticed when trying to manually update the firmware to install ffmpeg and just now when omxplayer tried to update the firmware.
puk
  • 695
