I cannot get internet access from a pizero connected via USB to a pi3 connected via ethernet.
        usb0 +---+
|ROUTER+----+PI3+v---+PIZERO|
         eth0
I tried to compile info from these articles to get where I am:
pi3 and piZero are running Raspbian Jessie Lite 2017-01-11. The Pi Zero was setup for headless OTG with the method described here: https://gist.github.com/gbaman/975e2db164b3ca2b51ae11e45e8fd40a#file-howtootgfast-md
I now have:
1 - pi3 configured with static ips (able to reach internet)
pi3 :: /etc/dhcpcd.conf
nohook lookup-hostname
# Static IP for ethernet access
interface eth0
static ip_address=192.168.178.77/24
static routers=192.168.178.1
static domain_name_servers=192.168.178.1
# Subnet for usb0 (where the piZero is plugged)
interface usb0
static ip_address=10.0.11.1/24
2 - pi3 able to do ipv4 fwd
pi3 :: /etc/sysctl.conf
net.ipv4.ip_forward=1
3 - pi3 firewall set up to allow eth0 / usb0 communication
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o usb0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i usb0 -o eth0 -j ACCEPT
The output of the rules has been saved into a file automatically loaded by rc.local. This is the result of iptable-save after each reboot:
# Generated by iptables-save v1.4.21 on Mon Feb 13 12:01:27 2017
*nat
:PREROUTING ACCEPT [30:2521]
:INPUT ACCEPT [24:2233]
:OUTPUT ACCEPT [30:2616]
:POSTROUTING ACCEPT [19:1581]
-A POSTROUTING -o eth0 -j SNAT --to-source 192.168.178.77
COMMIT
# Completed on Mon Feb 13 12:01:27 2017
*filter
:INPUT ACCEPT [339:38929]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [293:33013]
COMMIT
4 - piZero configured with static ips (reachable from pi3 with ssh pi@10.0.11.2 and ssh pi@raspberrypi.local)
piZero :: /etc/dhcpcd.conf
interface usb0
static ip_address=10.0.11.2
static routers=10.0.11.1
static domain_name_servers=10.0.11.1
Pinging 8.8.8.8 is successful on the PiZero:
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=55 time=5.43 ms
--- 8.8.8.8 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5006ms
rtt min/avg/max/mdev = 4.659/4.850/5.435/0.279 ms
But still no access to internet from the PiZero (impossible to ping stackexchange.com or to run apt-get update). Any ideas?
xav
  • 123
Did you try to ping 8.8.8.8 from the Zero? You told the piZero to use 10.0.11.1 as DNS, but maybe the RPi3 has none setup.
Did you also reboot the RPi3 after enabling ipv4 forward?
Are the iptables rules on the RPi3 still there? (could be that were lost during the the reboot if no persistency is enabled :))
EDIT: After seeing that @xav could ping 8.8.8.8 from piZero, it was proven that Internet Connectivity was there, however no DNS resolution. This was fixed by adding an public DNS server to the network config of the piZero:
interface usb0
static domain_name_servers=8.8.8.8
After an reboot of the piZero, it worked.
However, the piZero is not reachable from the main network 192.168.178.x due to the fact that the pcs in the main network do not know of the route to the piZero via the RPi3
nmaas87
  • 126
