I remember that when starting with Pi a few years ago (see this 2.5 year old question), it was impossible to SSH the Pi (without screen / keyboard / mouse) from computer with a USB cable only.
One had to use an ethernet cable, set up a network using a router, etc. It has to be noted that direct connection PC <--> Pi with an ethernet cable, without router, is quite complex to set up (I lost a few hours about this with Windows...)
I've recently seen that, with another similar board (maybe CubieBoard or another one?), there was a very-simple-to-use direct connection PC <--> Pi with a single USB cable.
Is this available in a recent version of Raspberry Pi (i.e. RPI3) or with a specific version of Raspbian?
Basj
  • 800
  • 49
5 Answers5
A direct data transfer connection to PCs via a single USB cable is only possible on the following models:
  • Raspberry Pi A
  • Raspberry Pi A+
  • Raspberry Pi Zero
  • Raspberry Pi Compute Module
All other models do not support USB device or USB-OTG slave mode. Please note that on all models except the Compute Modules and the Zero , it is impossible to transfer data over a Micro-USB port.
flakeshake
  • 6,244
  • 35
As the board is not electrically connected to the data lines of the USB, the micro USB port on most Pi models seems to be only usable for charging. However, you could rig up a USB based connection, using:
  • A USB to Serial adapter to the serial pins on the GPIO. Most adapters (I think I have successfully used the Adafruit one sold by ModMyPi) can also supply power via the GPIO, though this sort of isn't recommended as it bypasses the input fuse, so another USB cable can be used to provided power by USB (you will still need the ground connected to the serial adapter though). For instructions on interfacing this will help, but in short over this you can then do
    • A standard serial interface (this was supported in Raspbian images by default for all normal Pi models with the possible exception of Pi3) and then access a Linux console (Using a terminal client on a linux (and possibly Mac) clients, and in PuTTY on Windows clients)
    • Or via the Point-to-Point protocol, which basically emulates a network connection over the serial connection. Please note bandwidth is severely limited by the serial interfaces so transferring files via SFTP (and even large console messages) will be VERY slow. This also may be a pain to setup (even on a Linux client where it can be installed easily...) and the only vague benefit I found was to transfer files VERY slowly.
  • A USB-to-Ethernet adapter to a ethernet cable to the Pi's ethernet port (will likely require USB power still as AFAIK the Pi hasn't any Power over Ethernet capability). You don't have to use a gigabit adapter to do this, and also the computer connecting to the Pi should just see this as a extra network connection - you would still run into the connection issues you had with your computers normal Ethernet jack, but perhaps not as much as you can then use the normal connection to connect to the real Internet.
Wilf
  • 2,533
  • 39
It is not possible (although it may be with Pi Zero or A+).
It is possible with an Ethernet cable see How do I set up networking/WiFi/Static IP - "Connecting a Computer to the Pi"
The question you linked to is different from yours. They ask about a data connection via the charging port.
You don't mention that restriction in your question.
What you ask is possible. I have used it myself on a Pi 2 and Pi 3.
I've only tested it with an Android device, but there's no reason why you couldn't use a desktop PC running Windows, Linux, or OS X.
Edit /etc/network/interfaces and append these two lines:
auto usb0
iface usb0 inet dhcp
Then, on Android, I enable USB tethering and plug my phone into my Pi. My phone assigns my Pi an IP address, and I can then connect via SSH.
Aaron F
  • 166
Note: Apparently, this only works on Zero and A boards, not RPi 3, which is B.
With the microSD card in your computer, go to root folder of the boot volume and:
  1. add to config.txt:
    dtoverlay=dwc2
  2. append to the end of the line in cmdline.txt:
    modules-load=dwc2,g_ether
  3. create an empty ssh file to enable ssh
Then put the microSD in RPi, plug your USB cable to USB port (not PWR), wait a bit and then you should be able to ssh:
ssh pi@raspberrypi.local
Verified with RPi Zero W running Raspbian Stretch Lite.
All credit goes to https://www.thepolyglotdeveloper.com/2016/06/connect-raspberry-pi-zero-usb-cable-ssh/
Petr Bela
  • 101
