I need to power a Raspberry Pi 3 via its GPIO header: I have a beefy regulated PSU capable of providing stable 4.98V, which I planned to route to the 5V pins of the Raspberry as stated in this answer: How do I supply power through the GPIO?
The problem is I need to use a lot of 3.3V devices (3-4 ICs and various outputs) and I've read that I can only take ~80mA from the GPIO header reliably. I am planning to add an LM317 biased to provide the necessary voltage, but I am not sure if I can connect it back to the board or if I should leave it separated from the Raspberry and use it only for my other devices.
What is the safety margin I have to respect to be able to connect an external 3.3V to the Raspberry header?
Never connect a power source to a Pi 3V3 pin. You'll likely damage the Pi.
Power via one of the 5V pins - preferably with a 5V supply (you can use lower voltages but that will stop things which need 5V from working).
The 5V pin feeds in to the power supply chain which will then supply the 3V3 rail. You can draw say 750 mA from the Pi3's 3V3 rail. The often quoted 50 mA figure is for what may be supplied by the GPIO. The 3V3 rail is not a GPIO.
joan
  • 71,852
  • 76
  • 108
See Raspberry Pi Power Limitations
In particular NOTE the Foundation warning:- "Under no circumstances should a power source be connected to the 3.3V pins".
I am by no means an electronics guru and have nothing to back up my findings except experience, but I have run a Raspberry Pi3 for a minimum of 30 minutes with a 3.7v 500mAh Li-Po battery connected +to Pin1 and -to pin9. I have done this to record video while running a Lighttpd server to serve the video over the Internet. It seemed to function fine.
What will cause the Pi to fail is a mystery to me, but I own about 7 Pi's, so I am not concerned with a hardware failure.
My camera is hooked up to a servo to "look" higher and lower, I have NOT tested the servo while running the PI on the 3.7v Li-Po battery. This seems like it could pose a power supply problem. With my servo drawing 5v power from Pin4 (grounding to Pin6 and control at Pin12 [GPIO18]) then I would be relying on the Raspberry Pi3 to convert the voltage from 3.7v to 5.0v - that seemed like TOO MUCH to ask of it. I don't know why, but since I don't use 3.3v, I just think it's an "internal" voltage that they give us access to for reasons I have yet to explore.
I think the RAM, Processor, camera, and other "internals" can handle 3.3v or 3.7v just fine. I think the other "stuff" on the "board" itself is NOT designed to jump voltage UP so as to power 5v peripherals. Even low-power 5v LED's seem dangerous to me and and I am not willing to sacrifice a Pi to find out if I can "blink an LED" or move the Camera.
All I'm saying is that I HAVE had success running the Raspberry Pi3 model B V1.2 at 3.3 volts (I have NOT tried this on a Pi2 or any other version), but I don't think it is wise to try to use the GPIO pins if you do this.
I've just tested the setup on my Zero W board: fed it with 3.28V directly through 3V3 GPIO pin, and left 5V pin unconnected. Looks like it somehow works quite well: under CPU stress test it draws 0.5A from the external power supply, and temperature of the voltage regulator stabilizes at 33°C (with core temp reaching 57°C).
From the schematics it looks like the voltage regulator, seeing the voltage being less than 3.3V on its output, short-circuits 3V3 and 5V rails, therefore having some voltage on 5V rail to have something to make 1.8V from. Of course, anything requiring 5V to operate (HDMI or USB) will not work, but Wi-Fi works just fine.
I have this feeling, however, that going even a little bit above 3.3V will likely fry the voltage regulator (as it'll try to PWM-regulate the voltage on 3V3 rail and short-circuit it to the ground). Might make sense to feed the board through a Schottky diode to drop the supply voltage to something closer to 3.0V, just in case (have not tested it yet, though).
Goes without saying, other boards may have different voltage regulating schematics. I assume no responsibility for burned boards.
