Setup
I have a PI3 with Jessie. According to Wikipedia it uses a ARM Cortex-A53 which is ARMv8-A.
When installing node.js using this adafruit tutorial I end up with node v0.12 which is still beta stage.
Question:
I would like to use at least v4 of node.js. How do I install this and get it running?
Failed Approaches
First
This tutorial describes how to do it.
wget https://nodejs.org/dist/v5.0.0/node-v5.0.0-linux-arm64.tar.gz
tar -xvf node-v5.0.0-linux-arm64.tar.gz
cd node-v5.0.0-linux-arm64
sudo cp -R * /usr/local/ #attention copies also readme and other not required files
From v.4.0.0 Our test suite must be continually passing on ARMv6, ARMv7 and the new 64-bit ARMv8 processors.
V.5.0.0: ARMv8 64-bit Binary:
=> It is not able to execute the binary.
-bash: /usr/local/bin/node: cannot execute binary file: Exec format error
Second
https://github.com/nodesource/distributions#installation-instructions
Stops during sudo apt-get install -y nodejs
But I think they not yet have support for arm64 Github issue
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
gyp libc-ares-dev libc-ares2 libjs-node-uuid libjs-underscore libssl-dev
libssl-doc libv8-3.14-dev libv8-3.14.5 node-abbrev node-ansi
node-ansi-color-table node-archy node-async node-block-stream
node-combined-stream node-cookie-jar node-delayed-stream node-forever-agent
node-form-data node-fstream node-fstream-ignore node-github-url-from-git
node-glob node-graceful-fs node-gyp node-inherits node-ini
node-json-stringify-safe node-lockfile node-lru-cache node-mime
node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
node-normalize-package-data node-npmlog node-once node-osenv node-qs
node-read node-read-package-json node-request node-retry node-rimraf
node-semver node-sha node-sigmund node-slide node-tar node-tunnel-agent
node-underscore node-which
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
nodejs
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
Need to get 0 B/8,028 kB of archives.
After this operation, 38.3 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 125270 files and directories currently installed.)
Preparing to unpack .../nodejs_5.10.0-1nodesource1~jessie1_armhf.deb ...
Detected old npm client, removing...
Unpacking nodejs (5.10.0-1nodesource1~jessie1) ...
Message from syslogd@raspberrypi at Apr 6 09:47:46 ...
kernel:[ 294.455070] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
kernel:[ 295.546888] Process mmcqd/0 (pid: 52, stack limit = 0xb8cde210)
kernel:[ 295.618619] Stack: (0xb8cdfd88 to 0xb8ce0000)
kernel:[ 295.671359] fd80: 00000007 b9687680 b8cdfdc4 b8cdfda0 8043c924 8043cb34
kernel:[ 295.770515] fda0: b8cdfdc4 b8cdfdb0 8055fb5c b8cf0150 b9687400 b9687680 b8cdfdfc b8cdfdc8
kernel:[ 295.869667] fdc0: 8043d588 8043c738 b9687624 80441c80 b8cdfdfc b8cdfde0 80441c80 b8cf0150
kernel:[ 295.968821] fde0: b9687400 b8cf0258 b8cf0150 b8cdfea4 b8cdfe14 b8cdfe00 80424c54 8043d428
kernel:[ 296.067976] fe00: b9687400 00000000 b8cdfe64 b8cdfe18 80425980 80424b5c 00000001 b8cf0034
kernel:[ 296.167140] fe20: adec51d0 00000000 b8cb8600 8005f4f8 b8cdfe30 b8cdfe30 b8cdfe5c adec51d0
kernel:[ 296.266294] fe40: b8cf0008 b8cf014c b9687c00 b8cf0150 00000000 adec51d0 b8cdfed4 b8cdfe68
kernel:[ 296.365448] fe60: 80434494 804256e0 adec51d0 adec5220 b8cdfe94 b8cdfe80 802c88a0 802f97d4
kernel:[ 296.464600] fe80: b971e580 b971e584 b8cdfeb4 00000000 b8cf0000 00000000 00000000 80443bec
kernel:[ 296.563754] fea0: ffffffff 00ffffff b8cdfed4 b8cf0008 b9687c00 adec51d0 b8cf0000 b8cf0000
kernel:[ 296.662907] fec0: 00000001 24590411 b8cdff24 b8cdfed8 80434fd8 804343dc 00000000 adec51d0
kernel:[ 296.762059] fee0: b8cf8000 b8cde000 b8cdff0c b8cdfef8 802cf320 b9687400 b8cf0008 b8cf0008
kernel:[ 296.861214] ff00: b8cf8000 b8cde000 00000000 24590411 00000001 adec51d0 b8cdff5c b8cdff28
kernel:[ 296.960367] ff20: 804367c8 80434ee0 80436708 b8cf0010 00000000 b97151c0 00000000 b8cf0008
kernel:[ 297.059522] ff40: 80436708 00000000 00000000 00000000 b8cdffac b8cdff60 80042494 80436714
kernel:[ 297.158687] ff60: 8055fba4 00000000 b8cdff94 b8cf0008 00000000 00000000 b8cdff78 b8cdff78
kernel:[ 297.257840] ff80: 00000000 00000000 b8cdff88 b8cdff88 b97151c0 800423ac 00000000 00000000
kernel:[ 297.356994] ffa0: 00000000 b8cdffb0 8000f9f8 800423b8 00000000 00000000 00000000 00000000
kernel:[ 297.456177] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
kernel:[ 297.555354] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 55550000 55554000
kernel:[ 298.607208] Code: e89da818 e28400fc ebf11884 eafffff6 (e7f001f2)
