I've a lot of Raspberry Pi clients, which I've initialized with a 4.5.0 Node JS version, using the following lines of code:
wget https://nodejs.org/dist/v4.5.0/node-v4.5.0-linux-armv7l.tar.gz
tar -xvf node-v4.5.0-linux-armv7l.tar.gz
cd node-v4.5.0-linux-armv7l
cp -R * /usr/local/
// This copies the following files:
// bin CHANGELOG.md include lib LICENSE README.md share
Times changed and I noticed that meanwhile you install and manage Node using these lines of code:
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejs
// Do other stuff like rebuilding, etc.
I'd like to update all clients deploying a script, which leads us to my point. When I execute the update on my Test-Pi node -v returns v4.5.0 anyways, I think due to the fact that the old version is still located in /usr/local/.
I'd like to know, what's the best solution to update Node in my case and to be able to update / manage Node better in the future? Just remove node / npm files from the folders and run the update script?
