My very first Raspberry and I want to install the smart-mirror. When running npm start, it launches the home screen but also this error:
Error: The module '/home/pi/smart- mirror/node_modules/grpc/node/extension_binary/grpc_node.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 48. This version of Node.js requires NODE_MODULE_VERSION 51. Please try re-compiling or re-
installing the module (for instance, using 'npm rebuild' or 'npm install')
I tried both but ending up with the same error.
How do I fix it?
Piotr Kula
  • 17,336
  • 66
  • 105
This command will help you make sure curl is installed on your device
curl -sL https://raw.githubusercontent.com/evancohen/smart-mirror/master/scripts/pi-install.sh | bash
SDsolar
  • 2,378
  • 26
  • 43
Node is always outdated on any Rpi distribution. (Because of backward compatibility, fast development cycles of Node, and somewhat lazy maintenance efforts by the Rpi org.)
So you need to update it manually and that is not trivial as you need to remove a few node packages with package manager (apt) first and then re-install them with npm. Follow the instructions in my post here.
not2qubit
  • 1,439
