I am trying to configure my eth0 interface with a static ip through my dhcp server. The static assignment is working fine, but I can't access the external network because there's no default gateway.
pi@raspberry:~ $ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.0.30.0       0.0.0.0         255.255.255.0   U     202    0        0 eth0
If I run sudo dhclient or route add default gw 10.0.30.1 the default route is added and I can hit WAN no problem. But every time I restart the pi it loses this setting. How do I make this stay?
Here's my /etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
I looked at
Can't make change to "route" stick and "connect: Network is unreachable" on a working (connected) wlan0 interface and Static local IP/gateway config on startup issues but I didn't see a solution.
EDIT: Adding /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface eth0
inform 10.0.30.14
static routers=10.0.30.1
static domain_name_servers=8.8.8.8
static domain_search=8.8.8.4
EDIT 2: Adding ifconfig output
eth0      Link encap:Ethernet  HWaddr b8:27:eb:b1:50:55
      inet addr:10.0.30.14  Bcast:10.0.30.255  Mask:255.255.255.0
      inet6 addr: fe80::ba27:ebff:feb1:5055/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:1590 errors:0 dropped:0 overruns:0 frame:0
      TX packets:361 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:179536 (175.3 KiB)  TX bytes:56354 (55.0 KiB)
lo        Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:0 errors:0 dropped:0 overruns:0 frame:0
      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:e4:05:00
      inet addr:169.254.127.199  Bcast:169.254.255.255  Mask:255.255.0.0
      inet6 addr: fe80::d8fc:4221:1b8d:c2c2/64 Scope:Link
      TX packets:84 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:0 (0.0 B)  TX bytes:27244 (26.6 KiB)
Alex Haynes
  • 171
I managed to solve this by returning everything to defaults including /etc/dhcpcd.conf
Specifically once I removed these lines the default route appeared on boot
interface eth0
inform 10.0.30.14
Alex Haynes
  • 171
Do you have the following lines in your /etc/dhcpcd.conf file:
Especially the option classless_static_routes line.
You shouldn't have to but you may have to hard-code the default gateway by adding the following to the interface in /etc/network/interfaces:
iface wlan0 inet dhcp
    post-up route add default gw 192.168.1.254 eth0
    pre-down route del default gw 192.168.1.254 eth0
HeatfanJohn
  • 3,115
  • 26
  • 38
I did a change in "/etc/network/interfaces" and it works
iface eth0 inet static
address 192.168.1.111
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 10.0.30.1        --> edit to your IP Gateway
