I'm using a BT Homehub 3 and trying to set up my PI using raspbian with a static local IP.
Before any changes, using dhcp, the output of $ netstat -nr is
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.1.254   0.0.0.0         UG        0 0          0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U         0 0          0 eth0
The dhcp normally starts at 192.168.1.64 but I've changed this to 192.168.1.66. My windows server uses 192.168.1.64 and I want the Pi to use 192.168.1.65. The following shows changes I've made (commented out line 5,6 added line 8-14) to config in /etc/networking/interfaces:
auto lo
iface lo inet loopback
#auto eth0
#iface eth0 inet dhcp
auto eth0
iface eth0 inet static
address 192.168.1.65
netmask 255.255.255.0
network 192.168.1.254
broadcast 192.168.100.255
gateway 192.168.100.254
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
The config changes result in the local IP for the Pi changing but the output of $ netstat -nr is now the below and whilst I can access the Pi from the network on 192.168.1.65, I cannot access the internet from the Pi. I can see the problem, no gateway but as this is configured in the interfaces file above I'm stuck as to how to fix it.
$ sudo /sbin/route add -net 0.0.0.0 gw 192.168.1.254 eth0 at this point adds the requisite gateway and all works as required but I want this to be done automatically on startup.
Any help? Thank you.
Richard
Your configuration has the broadcast and gateway on a different network I think you meant this:
broadcast 192.168.1.255
gateway 192.168.1.254
(instead of 192.168.100.x)
Craig
  • 3,014
When you execute the following command on the shell, you are giving a Gateway IP Address that falls in the range of your Subnet Mask (255.255.255.0)
But in your /etc/networking/interfaces file, the gateway that you are giving is 192.168.100.254, which is not in the range of the subnet mask, hence possibly the problem.
I personally dont give the Gateway Address in the interfaces file, and it still works for me, when I use Static IP. (I never connect it to the internet though).
Jay K
  • 248
