46
I finally managed to make wlan0 (an Edimax EW-7811Un USB WiFi dongle) connect to my router, but after an apt-get update I discovered that my Raspberry can't connect outside the local network. The Raspberry is running on the latest (as of writing this) Raspbian image.
  • wlan0 is connected to my router and has been given an IP address
  • I can ping my router, my printer, and other machines inside the local network, but I can't ping anything in the outside net (also loopback ping on localhost says "host unreachable", but I'd say that it is NAT cancelling 127.0.0.1 requests)
  • I can successfully connect through eth0, but I need to connect through wlan0.
ifconfig output:
pi@MinoPi ~ $ ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr *macaddresshere*
      inet addr:192.168.1.9  Bcast:192.168.1.255  Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:552 errors:0 dropped:6 overruns:0 frame:0
      TX packets:289 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:375003 (366.2 KiB)  TX bytes:318051 (310.5 KiB)
iwconfig output:
pi@MinoPi ~ $ iwconfig wlan0
wlan0     IEEE 802.11bg  ESSID:"Sanctuary"  Nickname:"<WIFI@REALTEK>"
      Mode:Managed  Frequency:2.437 GHz  Access Point: *macaddresshere*
      Bit Rate:54 Mb/s   Sensitivity:0/0
      Retry:off   RTS thr:off   Fragment thr:off
      Power Management:off
      Link Quality=100/100  Signal level=100/100  Noise level=0/100
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:0   Missed beacon:0
/etc/network/interfaces file:
auto lo
iface lo inet loopback iface eth0 inet dhcp
iface wlan0 inet static address 192.168.1.9 netmask 255.255.255.0 gateway 192.168.1.1 wpa-ssid "Sanctuary" wpa-psk "somePasswordHere"
Any ideas?
Błażej Michalik
  • 1,313
Problem solved! It seems that even though I added the gateway information into the interfaces file, wlan0 didn't really have a default gateway.
When I ran
sudo route -n
it yielded
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 wlan0
There it is - no Gateway IP. I typed this:
 sudo route add default gw 192.168.1.1
(where 192.168.1.1 is an IP address of my router, which is connected to the outside net)
Et voilà: it works.
Błażej Michalik
  • 1,313
