I need a package that's in jessie, the newer version of Raspbian, but not in wheezy, the one I have installed. Can I use it somehow? Can/should I just upgrade to jessie?
Asked
Active
Viewed 1.2k times
9
Maybe -- you can try. Edit /etc/apt/sources.list.d/sources.list and add a line:
deb http://archive.raspbian.org/raspbian/ jessie main
Then run apt-get update. This may take a few minutes. Searching for the package should now show it, and you can try apt-get install [whatever]. You may have to pull in further substantial updates from jessie.
You can [as of Sept/2015, you probably should], but read the caveats below first.
First add the line as above above to sources.list, then:
apt-get dist-upgrade
You may also want to comment out the wheezy line from the sources.list above to prevent clutter or confusion in the future.
A few things to note about this:
- 60,325
- 17
- 117
- 234
