I can't install code block: sources.list got like this:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free r$
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspbian.org/raspbian/ wheezy main contrib non-free rpi
Installing:
sudo apt-get install codeblocks
 Reading package lists... Done
Building dependency tree
Package codeblocks is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  codeblocks-common
E: Package 'codeblocks' has no installation candidate
codeblocks-common doesn't works too
techraf
  • 4,353
  • 43
windman
  • 79
Run sudo apt-get update first to update the repositories and lists of packages and it's versions. I just tried to install it and had no issues.
Michielvk
  • 883
Diederik de Haas
  • 809
Debian's package manager can be a surly PITA. There may well be a way to untangle this properly, but in lieu of that here's something you can try.
There is certainly a ton of stuff in the codeblocks directory of the Raspbian repo, including what looks like v. 10.05 and 13.12 (note I'm not actually a codeblocks user). These are respectively the wheezy and jessie defaults. So unless you want to upgrade to jessie, you should try 10.05. You want the .deb file:
wget http://mirrordirector.raspbian.org/raspbian/pool/main/c/codeblocks/codeblocks_10.05-2.1_armhf.deb
This can then be installed directly with dpkg:
dpkg -i codeblocks_10.05-2.1_armhf.deb
I'm not promising that won't spit the same error, but I think it might not. It might instead fail because of a missing dependency, which you should try and install manually with apt-get and only if that fails start poking around in the repo as above. Keep track of anything you do install with dpkg, because if it doesn't work in the end you should probably remove all that stuff:
dpkg -r codeblocks_10.05-2.1_armhf
Note that's the name of the package sans the .deb file suffix this time. Dpkg has a manual page, see man dpkg.
