I'm trying to set up lirc on a Pi2 B+ running the latest Raspbian buster and latest kernel / firmware set by rpi-update.
I've started from this HOW-TO.
All I get from
sudo modprobe lirc_rpi
is:
modprobe: FATAL: Module lirc_rpi not found in directory /lib/modules/4.19.79-v7+
How do I get lirc to work?
Thanks in advance for your help!
sba923
  • 127
It really doesn't help using a tutorial from five years ago on a modern system. Too much has changed.
lirc_rpi has been replaced by dtoverlay=gpio-ir and dtoverlay=gpio-ir-tx in /boot/config.txt. See https://raspberrypi.org/forums/viewtopic.php?t=243583 for more details.
Dougie
  • 5,381
  • 22
  • 30
(1) How come LIRC stuff so old, any new tutorials and drivers out there?
(2) How to get LIRC to work in Rpi2B+ buster?
(1) You might find some updated stuff and some get around in Ref 1 below.
(2) The most updated tutorial on LIRC setup is dated 2019aug. I tried it and found it good (Ref 2, Appendix A).
/ to continue, ...
(1) Problem with LIRC on Raspberry Pi 3
(2) Setup LIRC on Rpi - StackfOverlow user1200233, 2019aug
/ to continue, ...
Appendices
Appendix A - LIRC Mode 2 Command Testing Record
I installed LIRC and tested remote controller OK (Ref 2). Mode 2 command display the pulse space data OK:
$ sudo mode2 -d /dev/lirc0
Using driver default on device /dev/lirc0
Trying device: /dev/lirc0 Using device: /dev/lirc0
Running as regular user pi
space 16777215
pulse 8936
space 4383
pulse 600 ...
End of answer
