I am trying to make I2C Communication between NodeMCU and arduino Uno boards. However it is not working properly. It makes communication for once time when i uploaded code.
Master Device Code(NodeMCU 1.0)
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <Wire.h>
HTTPClient client;
StaticJsonDocument <200> doc;
const char* ssid = "MY_SSID"; const char* pass = "MY_PASSWORD";
void setup() { Serial.begin(9600); Wire.begin(D1,D2); WiFi.begin(ssid,pass); while(WiFi.status() != WL_CONNECTED) {;} }
const char* cd = getCode(); if(cd==nullptr) {
Serial.println("Problem Occurred.");
delay(10000); return; } //Bad code is starting... //Basically, sending 24 bytes of data for a Wire Transmission
int n = strlen(cd); int rem = n%24; //remainder int quo = (n-rem)/24; //quotient
while(quo!=0) { char sel[24];
for(int i =0;i&lt;24;i++) {
  sel[i] = cd[((((n-rem)/24)-quo)*24)+i];
Wire.beginTransmission(8);
Wire.write(sel);
Wire.endTransmission();
quo-=1;
char sel[rem];
for(int i =0;i<rem;i++) { sel[i] = cd[n-rem+i]; }
if(rem>0) { Wire.beginTransmission(8); Wire.write(sel); Wire.endTransmission(); } //Bad code finished!
//this is also not working. Wire.requestFrom(8,3);
while(Wire.available()) { char c = Wire.read(); Serial.print(c); }
delay(15000); }
//get code from server. const char* getCode() { client.begin("http://...");
int res = client.GET();
if(res<0) { return 0; }
String root = client.getString(); deserializeJson(doc,root); const char* code = doc["Liste"][0]["code"]; return code; }
Slave Device Code(Arduino Uno)
#include <Wire.h>
void setup() { Serial.begin(9600); Wire.begin(8); Wire.onReceive(received); Wire.onRequest(requested); }
void loop() {delay(200);}
void received(int bytes) {
while (Wire.available()) { char c = Wire.read(); Serial.print(c); }
void requested() { Wire.write("abc"); }
Circuit:
D1-SDA
D2-SCL
GND-GND
You may need to do some additional research. I'm debugging some I2C problems myself at the moment. Happy to share what my research has turned up:
Guiding Ideas - What could break?
  1. Physical Layer
    1. Unintentionally switched connections (SDA<>SCL)
    2. Incorrect Pins selected on Microcontroller
    3. Pull-up Resistors
      1. Too many
        • Devices often have pull-ups installed by default. Only one set is needed per bus. Rule of parallel resistors applies to calculate effective resistance.
      2. Too big (too high resistance)
      3. Too small (too low resistance)
    4. Voltage Conversion / Mismatched  devices
    5. Spikes or noise on SDA, SCL or Vcc
    6. Parasitic Capacitance
      1. wire / trace design
      2. bus too long
  2. Protocol Layer
    1. Bus Addresses incorrect / collisions
    2. No ACK received from slave  (ref. TI article "Troubleshooting I2C Bus Protocol" below)
      1. Timing
      2. Missing / Unexpected SCL pulses
      3. Incomplete 8 bit block
      4. Missing Bytes
      5. False slave address
      6. Unsuccessful address change
    3. NACK signal meaning ambiguity
    4. Clock speed mismatch (should be running at the speed of the slowest slave on the bus)
    5. Blocked bus (i.e., a device has reset or dropped during transmission putting the bus into an invalid state. There is no timeout.)
    6. Multimastering (too many masters on bus?) - if more than one all must support multi-master mode
    7. Clock stretching (a slave is holding the clock low)
    8. What part of the message is missing? Is the initial ACK from the slave received?
  3. Code Layer
    1. For boards with multiple I2C ports, correctly passing the desired port to the relevant library.
    2. Use of interrupts causing timing problems
    3. Use of blocking code structures causing timing problems
Testing Methods
  • Bus Pinging / Bus Scan (like Arduino Multi-speed scanner https://forum.arduino.cc/index.php?topic=197360)
  • Connect additional devices to the bus and see which combinations work to identify the failing item
  • Multimeter checks
    • Stable Vcc?
    • Common Ground?
    • (Open Drain) pull-up resistance from SDA & SCL to Vcc
  • Test devices like Bus Pirate
  • Oscilloscope Analysis / Decode (references below)
  • Sifting out which device is causing the problem. (See Hackaday article) Put different-value resistors on the output of all chips on the bus. The low voltage values will be slightly different for each chip, allowing you to see on a scope which chip is talking at any given time, and diagnose when they’re talking over each other.
  • install I2C multiplexor to seperate bus into a single connector for each device (i.e., from bus to star topology) (e.g., PCA9544A)
I2C General
I2C Debug Advice
Oscilloscope Analysis of I2C
RowanP
  • 869
A few of my tips:
  1. if Arduino is powered using VIN port, the battery must STRICTLY between 7 to 12 volts, otherwise the Arduino board is unstable. Serial communication typically require good board stability
  2. A capacitor (100 to 500uF) across the 5V (or 3.3V) and GND port helps to give I2C device a consistent voltage level, which is essential
J Z
