When I remove the SD card and try to open a file, I can detect the error properly.
But how do I detect that the card has been replaced after an error? My first thought was to call SD.begin() again but it appears that this function returns true exactly once and false thereafter.
Simplified example:
  SD.begin(pin); // called exactly once. Works.
  // stuff
But this does not:
  SD.begin(pin); // first time calling this function: works.
  delay(1000);
  SD.begin(pin); // always fails
I'd rather not reset the microcontroller just for this.
Alex Shroyer
  • 437
I know this question is relatively old but still, if you wnat to run SD.begin(chipselect); again first call if(root.isOpen()) root.close(); I added this to the library. This way SD.begin(chipselect) will return true if a card is present and false when it's not.
Roschambo
  • 46
Update
A software reset, while inelegant, was much simpler to implement and debug than trying to add "retry" type functionality to SD.h. The other alternative would be to access SDFatLib.h or the other lower-level stuff (which SD.h is a wrapper for) directly, so if someone has that solution, I'll accept it instead of this one.
Original
Here is something, which is working well enough for me at the moment: does not reliably work:
bool SDState{false};
File LogFile;
bool trySDCard(void)
    // sanity check: maybe the SD card is actually here?
    LogFile = SD.open("test.txt", FILE_WRITE);
    delay(10);
    if (LogFile) {
        LogFile.close();
        return true;
    int8_t counter{10};
    while (counter && !SDState) {
        SDState = SD.begin(TFT_CARD_CS);
        Serial.print(counter);
        Serial.print(" ");
        counter--;
        delay(100);
    Serial.print("SD: ");
    Serial.println(SDState);
    return SDState;
    Serial.begin(115200);
    // NB. Simplified a lot (exitMenuMessage(string) is my custom function defined elsewhere)
    switch (state) {
        case SD_RETRY:
            exitMenuMessage(trySDCard() ? "found SD card" : "no SD card");
            break;
Seems to work Sometimes works if I insert the SD card while trySDCard() is running.
Alex Shroyer
  • 437
