I am working on an Arduino application that logs sensors values into SD files. It is essential that the SD is inserted and working when a test is started, thus I need to check the presence of the SD regularly (every 2 seconds or so) to prevent launching a test without SD inserted by the user.
When I run the following code, it runs very fast when the SD test succeeds (<10ms), but it takes more than 2000ms when the test fails. Is there another test I could run that does not takes 2 seconds to indicate that the SD is not inserted (or not working)? All my buttons are frozen and they do not trigger any action while checking if no SD is inserted.
Here is my code (both loops have the same issue):
#define csSD 53
#include <SD.h>
Sd2Card card;
Serial.begin(57600);
bool SDOK = SD.begin(csSD);
if(SDOK) {
Serial.println("SD.Begin Setup OK");
} else {
Serial.println("SD.Begin Setup Fail");
unsigned long t;
//void loop() {
// t=millis();
// if(SD.begin(csSD)){ // SD.Begin test runs fast when there is a SD, even though it return true when you try to begin SD a second time
// Serial.print("SD.Begin loop OK : ");
// }else {
// Serial.print("SD.Begin loop Fail : ");
// Serial.println(String(millis()-t)+"ms");
// delay(500);
t=millis();
if(card.init(SPI_HALF_SPEED, csSD)) {
// card.init test returns true as it should (when SD is present and working), but runs fast only when SD is working
Serial.print("card.init loop OK : ");
} else {
delay(500);
