At work, I have connected an Arduino to a security key (which has a 12v power supply) in order to give us a more versatile door lock. Unfortunately, people keep removing the key pad, disconnecting the wires and re-connecting them (defective keypad I guess.) In the process, I am afraid that they will accidentally send 12v into the Vcc, ground, digital in, and/or analog in pins. What is the best way to protect my Arduino from the 12 volts? I really need a component or two that I can to my pins.
Edit: it is difficult for me to describe this problem without mentioning the danger to all components. Please describe ways to protect digital outputs HERE
Hoytman
  • 747
There are some suggestions at Protecting Inputs in Digital Electronics .
Amended answer
Testing of my earlier answer involving clamping diodes gave unsatisfactory results. Due to the small current flow the diodes allowed a considerable voltage to reach the input pin (like, 9 V).
The amended circuit below, tested with 12V input, satisfactorily keeps the Arduino input pin to 4.9 V, even with 12 V from the device. The current through R1 is around 7 mA which is what you would expect:
I = V / R
I = 7 / 1000
I = 7 mA
The 1N4733A is a 5.1 V, 1 W zener diode which can therefore handle dropping 5 V at 7 mA.
In case you are wondering where the number 7 comes from in the calculations above:
  • The input voltage is 12 volts
  • The desired output is 5 volts
  • Therefore we need to drop (12 - 5) volts over the resistor
  • Thus 7 volts are dropped over the resistor
Input pin protection
Further reference material:
Nick Gammon
  • 38,901
