Moving strings to PROGMEM will only exacerbate the problem, since PROGMEM is the 32k flash.
You can easily get your "symbol table" from the compiled .elf file by using avr-objdump -t <.elf file>.
It results in a list something like this:
... scrolls past ...
00000338 g F .text 00000076 init
000000d4 g .text 00000000 __ctors_start
000000e2 g .text 00000000 __do_copy_data
00800110 g .bss 00000000 __bss_start
000008a2 g F .text 00000022 main
00000126 w .text 00000000 __vector_4
00000000 w *ABS* 00000000 __heap_end
00000126 w .text 00000000 __vector_9
000003ae g F .text 000000d0 delay
00000126 w .text 00000000 __vector_2
00000126 w .text 00000000 __vector_21
00000126 w .text 00000000 __vector_15
00000083 g O .text 0000000a port_to_output_PGM
00000154 g F .text 0000002e setup
008001c3 g .stab 00000000 __heap_start
000000d6 g .text 00000000 __dtors_start
000000d6 g .text 00000000 __ctors_end
000008ff w *ABS* 00000000 __stack
0000008d g O .text 0000000a port_to_input_PGM
00800110 g .data 00000000 _edata
008001c3 g .stab 00000000 _end
00000126 w .text 00000000 __vector_8
000000bf g O .text 00000014 digital_pin_to_timer_PGM
00000a08 w .text 00000000 exit
00000702 g F .text 00000052 _ZN14HardwareSerial4readEv
000009b8 g .text 00000000 __udivmodsi4
00000a08 g .text 00000000 _exit
00000126 w .text 00000000 __vector_14
00000126 w .text 00000000 __vector_10
000002a8 g F .text 00000090 __vector_16
00800100 g .data 00000000 __data_start
00000480 g F .text 00000076 __vector_18
00000126 w .text 00000000 __vector_20
00000108 g .text 00000000 __do_global_ctors
... etc ...
The lines you are interested in are .text sections. The first big number is the HEX location in memory. The second one is the important one - that is the size.
You can see from that snippet that the function delay is located at address 0x3ae and is 0xd0 bytes in size.
If you're on Unix or OSX you can employ the more advanced searching tools that are at your disposal. For instance, to just list the "global" .text entries:
$ avr-objdump -t <elf file> | grep '\.text' | grep ' g '
Which for my test program results in:
00000079 g O .text 0000000a port_to_mode_PGM
00000918 g F .text 00000040 _ZN5Print7printlnEv
00000a00 g .text 00000000 __tablejump__
000006c2 g F .text 00000040 _ZN14HardwareSerial4peekEv
000008c4 g F .text 00000054 _ZN5Print5writeEPKhj
000000d4 g .text 00000000 __trampolines_start
00000a0c g .text 00000000 _etext
000006a0 g F .text 00000022 _ZN14HardwareSerial9availableEv
0000012a g F .text 0000002a loop
00000774 g F .text 00000080 _ZN14HardwareSerial5writeEh
00000126 g .text 00000000 __bad_interrupt
000000d4 g .text 00000000 __trampolines_end
00000200 g F .text 000000a8 digitalWrite
00000592 g F .text 0000010e _ZN14HardwareSerial5beginEm
00000182 g F .text 0000007e pinMode
00000097 g O .text 00000014 digital_pin_to_port_PGM
000000d6 g .text 00000000 __dtors_end
00000754 g F .text 00000020 _ZN14HardwareSerial5flushEv
0000051c g F .text 00000076 __vector_19
00000990 g F .text 00000026 _ZN5Print7printlnEPKc
000000f8 g .text 00000000 __do_clear_bss
000000ab g O .text 00000014 digital_pin_to_bit_mask_PGM
00000000 g .text 00000000 __vectors
000009fc g .text 00000000 __tablejump2__
From that I can see that the function _ZN14HardwareSerial5beginEm is the biggest and takes up 0x10e bytes. That strange named function is a "C++ Munged" name. It actually corresponds to HardwareSerial::begin() and is the parent class name for Serial.begin().
