I have Arduino Code that utilizes the I2CDev library to control an MPU-6050. I am pretty new to coding and copied and pasted most of the code from examples I have found around. I am starting to run out of programming space on my Arduino, and I have found that one line of the code takes up 21%, or 6000 bytes of the programming memory. I found the function that the line related to and I have it shown below.
The link to the I2CDev libarary can be found on Github here as well: https://github.com/jrowberg/i2cdevlib
Is there a way to decrease it? Ot can someone explain to me why it is taking up so much space? Thanks!
uint8_t MPU6050::dmpInitialize() {
// reset device
DEBUG_PRINTLN(F("\n\nResetting MPU6050..."));
reset();
delay(30); // wait after reset
// enable sleep mode and wake cycle
/*Serial.println(F("Enabling sleep mode..."));
setSleepEnabled(true);
Serial.println(F("Enabling wake cycle..."));
setWakeCycleEnabled(true);*/
// disable sleep mode
DEBUG_PRINTLN(F("Disabling sleep mode..."));
setSleepEnabled(false);
// get MPU hardware revision
DEBUG_PRINTLN(F("Selecting user bank 16..."));
setMemoryBank(0x10, true, true);
DEBUG_PRINTLN(F("Selecting memory byte 6..."));
setMemoryStartAddress(0x06);
DEBUG_PRINTLN(F("Checking hardware revision..."));
DEBUG_PRINT(F("Revision @ user[16][6] = "));
DEBUG_PRINTLNF(readMemoryByte(), HEX);
DEBUG_PRINTLN(F("Resetting memory bank selection to 0..."));
setMemoryBank(0, false, false);
// check OTP bank valid
DEBUG_PRINTLN(F("Reading OTP bank valid flag..."));
DEBUG_PRINT(F("OTP bank is "));
DEBUG_PRINTLN(getOTPBankValid() ? F("valid!") : F("invalid!"));
// get X/Y/Z gyro offsets
DEBUG_PRINTLN(F("Reading gyro offset TC values..."));
int8_t xgOffsetTC = getXGyroOffsetTC();
int8_t ygOffsetTC = getYGyroOffsetTC();
int8_t zgOffsetTC = getZGyroOffsetTC();
DEBUG_PRINT(F("X gyro offset = "));
DEBUG_PRINTLN(xgOffsetTC);
DEBUG_PRINT(F("Y gyro offset = "));
DEBUG_PRINTLN(ygOffsetTC);
DEBUG_PRINT(F("Z gyro offset = "));
DEBUG_PRINTLN(zgOffsetTC);
// setup weird slave stuff (?)
DEBUG_PRINTLN(F("Setting slave 0 address to 0x7F..."));
setSlaveAddress(0, 0x7F);
DEBUG_PRINTLN(F("Disabling I2C Master mode..."));
setI2CMasterModeEnabled(false);
DEBUG_PRINTLN(F("Setting slave 0 address to 0x68 (self)..."));
setSlaveAddress(0, 0x68);
DEBUG_PRINTLN(F("Resetting I2C Master control..."));
resetI2CMaster();
delay(20);
// load DMP code into memory banks
DEBUG_PRINT(F("Writing DMP code to MPU memory banks ("));
DEBUG_PRINT(MPU6050_DMP_CODE_SIZE);
DEBUG_PRINTLN(F(" bytes)"));
if (writeProgMemoryBlock(dmpMemory, MPU6050_DMP_CODE_SIZE)) {
DEBUG_PRINTLN(F("Success! DMP code written and verified."));
// write DMP configuration
DEBUG_PRINT(F("Writing DMP configuration to MPU memory banks ("));
DEBUG_PRINT(MPU6050_DMP_CONFIG_SIZE);
DEBUG_PRINTLN(F(" bytes in config def)"));
if (writeProgDMPConfigurationSet(dmpConfig, MPU6050_DMP_CONFIG_SIZE)) {
DEBUG_PRINTLN(F("Success! DMP configuration written and verified."));
DEBUG_PRINTLN(F("Setting clock source to Z Gyro..."));
setClockSource(MPU6050_CLOCK_PLL_ZGYRO);
DEBUG_PRINTLN(F("Setting DMP and FIFO_OFLOW interrupts enabled..."));
setIntEnabled(0x12);
DEBUG_PRINTLN(F("Setting sample rate to 200Hz..."));
setRate(4); // 1khz / (1 + 4) = 200 Hz
DEBUG_PRINTLN(F("Setting external frame sync to TEMP_OUT_L[0]..."));
setExternalFrameSync(MPU6050_EXT_SYNC_TEMP_OUT_L);
DEBUG_PRINTLN(F("Setting DLPF bandwidth to 42Hz..."));
setDLPFMode(MPU6050_DLPF_BW_42);
DEBUG_PRINTLN(F("Setting gyro sensitivity to +/- 2000 deg/sec..."));
setFullScaleGyroRange(MPU6050_GYRO_FS_2000);
DEBUG_PRINTLN(F("Setting DMP programm start address"));
//write start address MSB into register
setDMPConfig1(0x03);
//write start address LSB into register
setDMPConfig2(0x00);
DEBUG_PRINTLN(F("Clearing OTP Bank flag..."));
setOTPBankValid(false);
DEBUG_PRINTLN(F("Setting X/Y/Z gyro offset TCs to previous values..."));
setXGyroOffsetTC(xgOffsetTC);
setYGyroOffsetTC(ygOffsetTC);
setZGyroOffsetTC(zgOffsetTC);
DEBUG_PRINTLN(F("Setting X/Y/Z gyro user offsets to zero..."));
//setXGyroOffset(0);
//setYGyroOffset(0);
//setZGyroOffset(0);
DEBUG_PRINTLN(F("Writing final memory update 1/7 (function unknown)..."));
uint8_t dmpUpdate[16], j;
uint16_t pos = 0;
for (j = 0; j < 4 || j < dmpUpdate[2] + 3; j++, pos++) dmpUpdate[j] = pgm_read_byte(&dmpUpdates[pos]);
writeMemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1]);
DEBUG_PRINTLN(F("Writing final memory update 2/7 (function unknown)..."));
DEBUG_PRINTLN(F("Resetting FIFO..."));
resetFIFO();
DEBUG_PRINTLN(F("Reading FIFO count..."));
uint16_t fifoCount = getFIFOCount();
uint8_t fifoBuffer[128];
DEBUG_PRINT(F("Current FIFO count="));
DEBUG_PRINTLN(fifoCount);
getFIFOBytes(fifoBuffer, fifoCount);
DEBUG_PRINTLN(F("Setting motion detection threshold to 2..."));
setMotionDetectionThreshold(2);
DEBUG_PRINTLN(F("Setting zero-motion detection threshold to 156..."));
setZeroMotionDetectionThreshold(156);
DEBUG_PRINTLN(F("Setting motion detection duration to 80..."));
setMotionDetectionDuration(80);
DEBUG_PRINTLN(F("Setting zero-motion detection duration to 0..."));
setZeroMotionDetectionDuration(0);
resetFIFO();
DEBUG_PRINTLN(F("Enabling FIFO..."));
setFIFOEnabled(true);
DEBUG_PRINTLN(F("Enabling DMP..."));
setDMPEnabled(true);
DEBUG_PRINTLN(F("Resetting DMP..."));
resetDMP();
DEBUG_PRINTLN(F("Writing final memory update 3/7 (function unknown)..."));
DEBUG_PRINTLN(F("Writing final memory update 4/7 (function unknown)..."));
DEBUG_PRINTLN(F("Writing final memory update 5/7 (function unknown)..."));
DEBUG_PRINTLN(F("Waiting for FIFO count > 2..."));
while ((fifoCount = getFIFOCount()) < 3);
DEBUG_PRINTLN(F("Reading FIFO data..."));
DEBUG_PRINTLN(F("Reading interrupt status..."));
DEBUG_PRINT(F("Current interrupt status="));
DEBUG_PRINTLNF(getIntStatus(), HEX);
DEBUG_PRINTLN(F("Reading final memory update 6/7 (function unknown)..."));
readMemoryBlock(dmpUpdate + 3, dmpUpdate[2], dmpUpdate[0], dmpUpdate[1]);
DEBUG_PRINTLN(F("Writing final memory update 7/7 (function unknown)..."));
DEBUG_PRINTLN(F("DMP is good to go! Finally."));
DEBUG_PRINTLN(F("Disabling DMP (you turn it on later)..."));
setDMPEnabled(false);
DEBUG_PRINTLN(F("Setting up internal 42-byte (default) DMP packet buffer..."));
dmpPacketSize = 42;
/*if ((dmpPacketBuffer = (uint8_t *)malloc(42)) == 0) {
return 3; // TODO: proper error code for no memory
DEBUG_PRINTLN(F("Resetting FIFO and clearing INT status one last time..."));
resetFIFO();
getIntStatus();
} else {
DEBUG_PRINTLN(F("ERROR! DMP configuration verification failed."));
return 2; // configuration block loading failed
} else {
DEBUG_PRINTLN(F("ERROR! DMP code verification failed."));
return 1; // main binary block loading failed
return 0; // success
