I tried installing the virtual key board as described here:
Virtual keyboard activation
on my RPI 3 model B Board
but it doesn't work at all
I get this when installing:
pi@raspberrypi:/ $ sudo apt-get install matchbox-keyboard
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
matchbox-keyboard : Depends: libfakekey0 (>= 0.1) but it is not going to be installed
                 Recommends: matchbox-keyboard-im but it is not going to be installed
 python2.7 : Depends: python2.7-minimal (= 2.7.9-2+deb8u2) but 2.7.9-2+deb8u1 is to be installed
         Depends: libpython2.7-stdlib (= 2.7.9-2+deb8u2) but 2.7.9-2+deb8u1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried this:
pi@raspberrypi:/ $ apt-get -f install
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
pi@raspberrypi:/ $
Brick
  • 1,375
Please look at the very last question: are you root?. That is what you get by prefixing your commands with sudo. So try your command with:
rpi ~$ sudo apt-get -f install
Ingo
  • 42,961
  • 207
