I built a buggy:
https://projects.raspberrypi.org/en/projects/build-a-buggy/2
it seems like it works correctly, except the motor doesn't stop even when I run robby.stop() is there some other command I should use instead?
Program I Ran:
from gpiozero import Robot
robby = Robot(left=(7,8), right=(9,10))
then in the python shell I ran robby.forward() which started the motor.
NOTE: When the board has power the motor goes forward even with the pi turned off.
gpioZero buggy won't stop! :(
Update 2019jun22hkt1113
4wd
Try my L298N python program for your buggy! :)
# Driving One Motor Using GpioZeo and L298N v0.01  tlfong01  2019jun11hkt1156
# rpi3B+ python 3.5.3 gpiozero 1.5.0 L298N
# wiring -
from time import sleep
from gpiozero import Motor
motor = Motor(17, 18)
motor.forward()
sleep(2)
motor.backward()
sleep(2)
motor.reverse
sleep(2)
motor.stop()
gpiozero motor
Build a robot buggy - Rpi.org projects
GpioZero Robot
GpioZero Motor
GpioZero Composite Device
GpioZero Device
Source code for gpiozero.output_devices [v1.5.0]
Source Code for gpiozero.motor [v1.2.0]
Choosing Motors - tlfong01 2019mar11
Appendices
Appendix A - Summary of Class motor and its methods
class Motor():
def forward():
Drive the motor forward
def backward():
Drive the motor backward
def reverse():
Reverse the current direction of the motor
def stop():
Stop the motor.
