Asking the other day this question I discovered a new fascinating world, the gpio zero library.
My first code was this (an example to blink a led):
from gpiozero import LED
from time import sleep
red = LED(21)
while True:
    red.on()
    sleep(1)
    red.off()
    sleep(1)
It works when I run it on my raspberry.
But the purpose to learn to work with this new library is to control my gpios remotely from my laptop. And to do this, they explain it here.
But I don't understand how to do it, because they said here that I only have to write this on my laptop (windows, pycharm) program:
PIGPIO_ADDR=192.168.1.3 python3 led.py
When I run it, appears the error:
SyntaxError: invalid syntax
It's obviously I am missing things, and I'm sure it's easy but I really don't know what can I try, and I don't find to much info.
(I don't know if it is important but my code led.py is /home/pi)
Lleims
  • 210
PIGPIO_ADDR=192.168.1.3 python3 led.py is a terminal command. If you're using PyCharm on Windows, you need to either:
  1. Set an environment variable within PyCharm
  2. Set an environment variable within Windows
  3. Use another approach, set the pin factory within the code:
from gpiozero.pins.pigpio import PiGPIOFactory
pi = PiGPIOFactory('192.168.1.3')
red = LED(21, pin_factory=pi)
while True:
    red.on()
    sleep(1)
    red.off()
    sleep(1)
or:
from gpiozero import Device, LED
Device.pin_factory = PiGPIOFactory('192.168.1.3')  # set the default pin factory
red = LED(21)
while True:
    red.on()
    sleep(1)
    red.off()
    sleep(1)
ben_nuttall
  • 2,471
