I would like to be able to read values of two thermal couples and a pressure gauge using my raspberry pi. Recording the data and then sending it to a server at the end of the day.
I am using dual t/c thermal couples. Link for the them. https://www.omega.com/en-us/sensors-and-sensing-equipment/temperature/sensors/thermocouple-probes/p/ICIN-DUAL
I wanted to use this pressure sensor: http://www.revrobotics.com/rev-11-1107/
I was going to use a Raspberry Pi B with a breakout board: To read each value of voltage and then calculate real values in the code.
This breakout board: https://store.ncd.io/product/3-channel-4-20-ma-current-loop-receiver-16-bit-ads1115-i2c-mini-module/
If anyone can explain to me a better way to do this. I would be happy to listen I am confused on the breakout board because the board only has two connections per channel.
Max
  1. Read 2 thermal couples and 1 pressure gauge using Rpi
  2. Record data and send it to server
  3. A better way to do this?
I skimmed the datasheet of your thermal sensor, pressure sensor, and current loop receiver module. My first impression is that they are all mission critical, industrial equipment.
Electrical characteristics of 3 pieces of equipment
  1. Thermal sensor: 4 thermal conducting wire, 4~20mA current loop
  2. Pressure sensor: power = 5V, signal output = 0.5V to 4.5V
  3. ADC module: INA196/ADS1115 based current/voltage ADC
Rpi to ADC module Interface Summary
  1. Communication protocol: I2C
  2. Programming languages (suggestion): python, C/C++, NodeJs, NodeRed
Advice / Warning to Rpi I2C ADC (INA196/ADS1115) newbies
I am new to building things like this and guess I just got confused. So for the pressure sensor I can just ignore one of the cables? Using the ground and signal cable. – Max 5
Well, your above comment worries me "a bit". During last couple of months I have been playing as an electronics/programming hobbyist, the hardware/software related to your project: current loop sensors including INA221, ADC including ADS1115, ...
The current sensor INA219 and voltage ADC 16 bit ADS1115 used in you project has a rather steep learning curve for newbies. You might like to first read the following posts on using these devices, to get a feeling of how hard it is. If you indeed found it scary, then I can recommend two simple devices ACS712 (current sensing and ADC combined, saving trouble for newbies) and PCF8591 (ADC, but 8 bit only). You can use these newbie friendly devices as a warm up exercise, before researching on you more advanced, industrial grade equipment.
Reading Voltage Input on ADC [using ACS712 and INA221]
Raspberry Pi Current & Voltage Sensors [using INA219/INA226, ACS712, ADS1015/ADS1115, ADS1256/AD7190]
/ to continue, ...
Dual Element Thermocouple probe with Standard Size Connector
Specifications
Two Sensor Readings Allows Two Readings of a Single Point
Continuous Monitor and Control & Built-in Backup
Analog Pressure Sensor
Specification
Typical Supply Voltage: 5VDC
Output Voltage Range: 0.5 – 4.5VDC
3-Channel 4-20 mA Current Loop Receiver 16-Bit ADS1115 I2C Mini Module
Features
3 Channel 4-20 mA Current Loop Receiver
3-Channel Input with 16-Bit Resolution
4-20mA Industrial Sensor Monitoring
INA196 Current Shunt Monitoring
Ideal for Sensor and Instrument Monitoring
ADS1115 16-Bit Analog to Digital Converter
Onboard 16V Voltage Supply (Boosted from 5V)
Ideal for Industrial Automation 4-20mA input
