ifplugd is running as daemon so we have to use a systemd service to manage it. I will only use the daemon program /usr/sbin/ifplugd without the management scripts from Debian.
Tested with
Raspberry Pi OS 2020-12-02 based on Buster on a Raspberry Pi 4B updated at 2020-05-12.
Raspbian Stretch Lite 2019-04-08 updated at 2019-04-16.
Updates done with sudo apt update && sudo apt full-upgrade && sudo reboot.
Install ifplugd program
First we download the ifplugd package but don't install it, only extract the daemon program:
rpi ~$ apt download ifplugd
rpi ~$ ar -p ifplugd_*_armhf.deb data.tar.xz | sudo tar -xJ -C / ./usr/sbin/ifplugd
rpi ~$ rm ifplugd_*_armhf.deb
rpi ~$ ifplugd --version # at the time testing this
ifplugd 0.28 (SVN: 124)
Create new service for the ifplugd program
We will not run ifplugd as classic daemon. Instead we run it as service and do not have to "daemonize" it. Look at the man page (1) that we have to use option --no-daemon. Other options are used to disable functions that are managed by systemd now. Create the new service with:
rpi ~$ sudo -Es
rpi ~# systemctl --full --force edit ifplug@.service
In the empty editor insert these statements, save them and quit the editor:
[Unit]
Description=Interface plug monitor (interface-specific version)
Documentation=https://raspberrypi.stackexchange.com/a/96605/79866
After=sys-subsystem-net-devices-%i.device
[Service]
ExecStart=/usr/sbin/ifplugd --iface=%i --no-daemon --no-auto --no-syslog --no-beep --no-shutdown --run=/etc/ifplugs/ifplugs.action
[Install]
WantedBy=sys-subsystem-net-devices-%i.device
Create Action Script
As described in the man page (1) the service calls a script on every event up and down on an interface. Here I will use a template. Create this action script with your editor:
rpi ~# mkdir /etc/ifplugs
rpi ~# editor /etc/ifplugs/ifplugs.action
#!/bin/bash
# redirect all output into a logfile for debug
#exec 1>> /tmp/ifplugs-debug.log 2>&1
INTERFACE="$1"
EVENT="$2"
IPADDR=''
get_ipaddr () {
if [ "$EVENT" = "down" ]; then
IPADDR=$(/sbin/ip -4 -br addr show $INTERFACE | /bin/grep -Po "\d+.\d+.\d+.\d+")
return 0
fi
# check 10 times with 1 sec delay if ip address is available
for ((i=10; i>0; i--)); do
[ $? -eq 0 ] && break
/bin/sleep 1
done
case "$INTERFACE" in
eth0)
case "$EVENT" in
up)
# do stuff on connect with interface
get_ipaddr
echo "$INTERFACE" up with ip address ""$IPADDR""
down)
# do stuff on disconnect with interface
get_ipaddr
echo "$INTERFACE" down with ip address ""$IPADDR""
>&2 echo empty or undefined event for "$INTERFACE": ""$EVENT""
exit 1
esac
wlan0)
case "$EVENT" in
up)
get_ipaddr
down)
get_ipaddr
exit 1
esac
>&2 echo empty or unknown interface: ""$INTERFACE""
exit 1
esac
Make it executable:
rpi ~# chmod +x /etc/ifplugs/ifplugs.action
/usr/sbin/ifplugd needs an own instance for every interface. So we start them with the interface-specific version:
rpi ~# systemctl start ifplug@eth0.service
rpi ~# systemctl start ifplug@wlan0.service
rpi ~# exit
rpi ~$
If you want to start the ifplug.service on boot up, just enable it:
rpi ~$ sudo systemctl enable ifplug@eth0.service
rpi ~$ sudo systemctl enable ifplug@wlan0.service
Now the actions up and down for each monitored interface are logged to the journal. Follow it with
rpi ~$ journalctl --follow
You may filter it with:
rpi ~$ journalctl --follow | grep ifplugd
You are free to modify /etc/ifplugs/ifplugs.action or create your own. If you want to monitor other interfaces then just use its interface names for the interface-specific services and in the action script instead of eth0 and wlan0 in this example.
References:
(1): man page ifplugd
