I am trying to make my RPI 4 execute a script, when it connects to a network (be it cable or wifi) i.e when it goes from not connected to connected.
I am running Raspbian (Buster) as OS and on Ubuntu 18.04 I can simply put the script in NetworkManager/dispatcher.d but since NetworkManager is not installed on my RPI (and I want to keep as clean an installation as possible) I tried to place it in /etc/network/if-up.d based on different answers years ago - it seems like if-* not used any more or..?
Any idea?
Test-script:
#!/bin/sh
echo "WORKING">out.txt
CutePoison
Dhcpdcd, which is used for DHCP client negotiation by default in Raspbian/RpiOS, has a "hooks" directory in /lib/dhcpcd/dhcpcd-hooks. Beware not to confuse dhcpcd with dhclient, which can serve much the same purpose and also entertains hooks (but is not used by default), or dhcpd (one less letter), which acts as a DHCP server (the cd in dhcpcd is for "client daemon").
man dhcpcd-run-hooks documents this very succinctly. When the script is run by dhcpd, the environment will contain a bunch of variables with information. There is a list of a dozen or so reasons that this will happen; the specific one will be in $reason.
Try placing this there:1
reportLog=/some/absolute/path/dhcpcd-report.log
msg() { echo $@ >> $reportLog }
date >> $reportLog msg Invoked for $reason
'printenv' dumps all the environment variables
printenv >> $reportLog
echo >> $reportLog
An example of the output:
Mon Jan 25 17:12:03 EST 2021
Invoked for BOUND
new_subnet_cidr=24
new_ip_address=192.168.0.21
new_network_number=192.168.0.0
pid=427
new_dhcp_message_type=5
if_down=false
ifmtu=1500
new_routers=192.168.0.1
new_subnet_mask=255.255.255.0
interface=wlan0
new_domain_name=hitronhub.home
reason=BOUND
ifcarrier=up
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
ifssid=ISS2
protocol=dhcp
interface_order=lo eth0 wlan0
new_host_name=raspberrypi
if_up=true
new_dhcp_server_identifier=192.168.0.1
new_domain_name_servers=64.71.255.204 64.71.255.198
new_broadcast_address=192.168.0.255
WPAconfig=/etc/wpa_supplicant/wpa_supplicant.conf
ifflags=69699
PWD=/
ifmetric=303
ifwireless=1
new_dhcp_lease_time=604800
A couple of the variables are inherited from the system ($PATH, $PWD), the rest are all from dhcpcd (many/most of them are described in the hooks man page). Of particular relevance to you is of course if_up=true. You'll have to experiment a bit to decide when you should do what it is you want to do. For example, there's a distinction between an interface going up and an actual connection being established, and some specific combination of $reason and $interface may be the key you want to watch for; if you just do it every time a hook is run with if_up=true you will end up doing it three or four times in rapid succession, etc.
  1. Dhcpcd executes this via sh (which is why there is no point in a shebang #!/___), meaning you can't use bashisms like exec &> to redirect all output (hence the cumbersome msg() function above) or capture the output of a command in a variable with foo=$(bar). However, you can get around that by making the hook script just:
     /bin/bash /path/to/some/bashscript.sh
You could do something similar to run a python script or execute anything; those environment variables are inherited.
In the "good old days" there was ifplugd available with Debian networking, managed with /etc/network/interfaces. It monitors the network interfaces and calls a script if they change their state. But Debian networking isn't well supported on the Raspberry Pi OS, because it uses dhcpcd by default.
I have made ifplugd available again with systemd-networkd. How to use it you can look at Make ifplugd available with systemd. You can also find a practical example at How to make Raspian Buster shutdown when I unplug the ethernet cable.
Ingo
  • 42,961
  • 207
The
dhcpcd-run-hooks
method worked for me.
I needed to activate a broadband usb-key connection before dhcpcd start to search for an IP on my wan interface
As stated from man dhcpcd-run-hooks i wrote my script in /etc/dhcpcd.enter-hook that is executed before system provided hooks in /lib/dhcpcd/dhcpcd-hooks If you need to execute your script as the last one put it in /etc/dhcpcd.exit-hook instead.
