I'm having trouble installing a dependency on libc6. I'm trying to follow the solution in this question but I get the following response from sudo apt update:
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Ign:3 http://apt.mopidy.com stretch InRelease
Hit:4 http://apt.mopidy.com stretch Release
Get:5 http://ftp.us.debian.org/debian sid InRelease [242 kB]
Err:5 http://ftp.us.debian.org/debian sid InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010 NO_PUBKEY 04EE7237B7D453EC
Reading package lists... Done
W: GPG error: http://ftp.us.debian.org/debian sid InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010 NO_PUBKEY 04EE7237B7D453EC
E: The repository 'http://ftp.us.debian.org/debian sid InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I've tried running gpg --keyserver keyring.debian.org --recv-keys 7638D0442B90D010 and similar with different keyservers, but none of them respond. I really don't have any idea what I'm doing: what's the problem and how do I fix it?
You mixed up Raspbian with Debian repositories and in addition the stable release (stretch) with the unstable release (sid). More mixing is hardly possible. This cannot work. You should edit /etc/apt/sources.list and use only the stable release stretch from the Raspbian repository as set by default.
Or you may try to use the testing version buster. Then you have to replace the version stretch with buster in /etc/apt/sources.list and in /etc/apt/sources.list.d/raspi.list. Then on a stretch installation do sudo apt update && sudo apt full-upgrade.
The unstable version sid is not available on the Raspbian repositories.
The link you have given to another question has some answers but no one was accepted. The whole repository is compiled against its kernel and modules. Raspbian has its own kernel, modules and drivers. I don't believe that it fits in all cases to the Debian repository.
Mixing different versions (e.g. stable with testing) is a very complicated task. The parts from the higher version also needs the libraries of the higher version and they will complain it with an error message. So you end up in an installation with mixed libraries that are also used by the programs with lower version. I haven't made good experience with this. It is the reason why Debian have made the backports with new programs linked against old libraries.
Ingo
  • 42,961
  • 207
