I am trying to install libwvstreams4.6-base offline using dpkg. I am getting a dependency error for libc6 ( >= 2.15) but I am unable to find this required version for raspbian. Currently, libc6 2.13 is installed on my RPi. Due to some reasons, I cannot connect my RPi to a WiFi or a wired ethernet and need to install wvdial and libwvstreams to enable dongle usage.
- 233
- 2
- 4
- 8
You can use unstable packages. Just add this line to /etc/apt/sources.list:
deb http://ftp.us.debian.org/debian sid main
To upgrade your packages, run
apt-get update && apt-get upgrade libc6
- 69
- 2
If you emulate a Raspberry Pi using QEMU (as detailed here) then you can load the image and install your packages from the internet on your Ubuntu machine.
After you've installed the packages, take the modified image and flash it to SD card as normal. It will keep all the changes that you made in the emulated environment.
This is probably much easier that resolving all the package dependencies.
The version of libc6 depends on the release of raspbian you are running, right now wheezy has 2.13-38+rpi2+deb7u10 jessie has 2.19-18+deb8u3 and stretch has 2.22-4
I would guess that your problem is you are trying to install packages intended for jessie on a wheezy system.
- 6,595
- 1
- 21
- 26
Add unstable packages with
sudo sh -c 'echo "deb http://ftp.us.debian.org/debian sid main" > /etc/apt/sources.list'
and upgrade packages
- 141
- 1
- 9
Update Whizzy 1st
% sudo apt-get update
% sudo apt-get upgrade
% sudo apt-get dist-upgrade
After that rewrite 'whizzy' to 'jessie' in whole text below.
% sudo nano /etc/apt/sources.list
% sudo nano /etc/apt/sources.list.d/collabora.list
% sudo nano /etc/apt/sources.list.d/raspi.list
Now, we can update again as a Jessie.
After update, reboot your RPi
% sudo reboot
Finally you can see a new version of libc6
$ sudo dpkg -l libc6
ii libc6:armhf 2.19-18 armhf GNU C Library: Shared libraries
It will took a 3HR or more.... Have fun!
Yoshi
- 9
- 1
