I've been trying to make my own lower-cost power supply for the Raspberry Pi (my cellphone wall adapters don't provide clean enough 5V power for the Pi 3B+) with a 12V wall wart I have laying around and a spare switching regulator.
I have the switching regulator set so it outputs 5.23V while unloaded, but upon being connected to the Pi, the voltage sags to ~4.7V. Given that the target input voltage range for the Pi is ~4.9-5.1V, how high is it safe to set the switching regulator in order to ensure that even its sagged voltage is within the range? Could I safely go to 5.5V unloaded voltage?
ifconfig
  • 127
The voltage requirement for all model Pi's is 5V +/- 5% (min 4.75V, max 5.25V) which is the USB standard.
Raspberry Pi Power Limitations
As noted by a Raspberry Pi moderator:
if your power supply peaks above 5.25V, it may damage any USB devices connected to it.
https://www.raspberrypi.org/forums/viewtopic.php?t=216219#p1329717
CoderMike
  • 7,102
