I want add-on SD card reader/writer/slot/controller in my raspberry pi so that i can keep OS separate from my program. Primary SD card will load OS and work normally and program & data will remain available from add-on card. Please suggest
a) what good hardware extension or component available as add-on card for raspberry pi 3b
b) suitable software available.
OR if i can use USB Pendrive directly because i have USB slots spare. How?
Please note: 1) I am not talking about increase SD card size and 2) not talking about creating separate partition on first SD card.
Thanks
JPI
  • 129
You can use USB pendrives as much as you have free USB slots. If you want to keep programs and data on different storrages you can follow Debian - Recommended Partitioning Scheme.
For new users, personal Debian boxes, home systems, and other single-user setups, a single / partition (plus swap) is probably the easiest, simplest way to go.
For multi-user systems or systems with lots of disk space, it's best to put /var, /tmp, and /home each on their own partitions separate from the / partition.
Following this you must not use separate partitions on the pendrive(s) for /var, /tmp, and /home. You can also use separate directories on one partition for them. You are free how to divide the data(-directories) on partition(s).
Ingo
  • 42,961
  • 207
You can use any USB device to boot a 3B, 3B+ or 3A. (some 2Bs even support that).
You can use an SD, USB stick, USB hard drive or USB SSD.
Splitting the boot drive from the base filesystem makes no sense. Adding a drive mounted at /media or /mnt is normal and commonly used.
Go and search on https://raspberrypi.org/forums where there's a massive number of posts about this. There's even a thread on there about running a read-only filesystem.
Dougie
  • 5,381
  • 22
  • 30
If you want to go down the route of specifically using another SDCard type unit for a secondary storage device you can, if I recall correctly, get SPI modules that you can wire up to that bus (three or four signal lines plus a couple for power and ground). I would imagine that they would be available from on-line auction or retail sites.
On the other hand, USB storage devices make the same sort of thing a much easier thing to organise provided you have the available slots and space for the hub if needed as well as a USB flash drive.
Finally, the underlying SoC hardware does have support for a second SD Card interface however I am not sure that that is accessible on anything other than the Compute Module / Compute Module 3 devices which have a lot more of the connections available, it is also not clear to me either what support circuitry will need to be added to make use of that.
Update: I have tracked down the following which might provide some useful information:
SlySven
  • 3,631
  • 46
