I want to use Bluetooth of Raspberry Pi3 and also I want to Connect GSM module sim800l to Raspberry Pi3 ,in this instruction Bluetooth will be disable , what is the the best way to use both of them?
From this link I add enable_uart=1 in /boot/config.txt and I did this:
sudo apt-get install ppp
sudo wget "https://www.modmypi.com/download/sakis3g.tar.gz" -O sakis3g.tar.gz
sudo tar -xzvf sakis3g.tar.gz
sudo chmod +x sakis3g
sudo nano /etc/sakis3g.conf
in sakis3g.conf I added this :
CUSTOM_TTY="/dev/ttyS0"
BAUD=9600
APN=CUSTOM_APN
CUSTOM_APN=”sim apn”
I run sudo ./sakis3g ----interactive connect the ouput is
Modem unable to register a network.
connection failed
The sim doesn't have password So why the module cannot connect to internet?
isan
The tutorial you linked uses rpi-update
"In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 Even the rpi-update documentation now warns "Even on Raspbian you should only use this with a good reason. This gets you the latest bleeding edge kernel/firmware."
sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel will put it back to the latest supported kernel/bootcode.
There is NO reason to disable Bluetooth.
To use serial use dev/serial0 see How do I make serial work on the Raspberry Pi3 , Pi3B+, PiZeroW
