I have installed lighttpd on my RPI 3 :
sudo apt-get install lighttpd
I have managed to access the web server from /home/pi/www And it works, I can find my Hello World when I entered 192.168.2.31 in my URL browser.
Now I try to access my raspberry pi through mDns. In this way I have installed AVAHI :
sudo apt-get install avahi-daemon libavahi-client-dev
I have modified my hostname :
Sudo raspi-config
and then select Network option then select Hostname then I have called it raspberrypik
I have updated my reboot system :
sudo update-rc.d avahi-daemon defaults
Now I try to access my web server from my browser, from either Windows 10 where Itunes is installed and my smartphone (I shared the Hotspot of my cellphone with the RPI) by typing raspberrypik.local but nothing happen.
Some tutorials use AVAHI to get acces on the RPI through SSH. I tried to access my RPI via SSH with raspberrypik.local, but nothing...
I have tried what is indicated in this post : How to debug avahi-daemon? Hostname not coming through
But when I do
$ ls -l /etc/avahi/services/
total 4
-rw-r--r-- 1 root root 243 Aug 2 05:53 ssh.service
The folder multiple.service and udisks.service are not present, is it normal ?
When I do :
$ avahi-browse -a
-bash: avahi-browse: command not found
When I ping I get :
~ $ ping -c 4 raspberrypik
PING raspberrypik (127.0.1.1) 56(84) bytes of data.
64 bytes from raspberrypik (127.0.1.1): icmp_seq=1 ttl=64 time=0.108 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=2 ttl=64 time=0.076 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=3 ttl=64 time=0.098 ms
64 bytes from raspberrypik (127.0.1.1): icmp_seq=4 ttl=64 time=0.104 ms
--- raspberrypik ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3098ms
rtt min/avg/max/mdev = 0.076/0.096/0.108/0.015 ms
Now if I follow the post I get :
~ $ avahi-resolve
-bash: avahi-resolve: command not found
And finally :
~ $ tcpdump -i wlan0 port 5353 or igmp -w /tmp/mdns.pcap
-bash: tcpdump: command not found
Ok I do things wrong, but where ??
Thank you for your help
