15
I installed Avahi with libnss-mdns to be able to access my pi by hostname. Relevant info:
$ cat /etc/hostname
raspberrypi
$ ps ax | grep avahi
2103 ?        S      0:00 avahi-daemon: running [raspberrypi.local]
2104 ?        S      0:00 avahi-daemon: chroot helper
$ sudo service avahi-daemon status
Avahi mDNS/DNS-SD Daemon is running
ls -l /etc/avahi/services/
total 8
-rw-r--r-- 1 root root 449 Jul 31 13:16 multiple.service
-rw-r--r-- 1 root root 299 Mar 10 17:15 udisks.service
And on the pi itself it is working:
$ avahi-browse -a
+   eth0 IPv4 XBMC (raspberrypi)                            _airplay._tcp        local
+   eth0 IPv4 B827EBA83303@XBMC (raspberrypi)               AirTunes Remote Audio local
+   eth0 IPv4 XBMC (raspberrypi)                            _xbmc-jsonrpc._tcp   local
+   eth0 IPv4 XBMC (raspberrypi)                            _xbmc-events._udp    local
+   eth0 IPv4 XBMC (raspberrypi)                            _xbmc-jsonrpc-h._tcp local
+   eth0 IPv4 XBMC (raspberrypi)                            Web Site             local
+   eth0 IPv4 raspberrypi                                   Remote Disk Management local
+   eth0 IPv4 raspberrypi                                   _device-info._tcp    local
+   eth0 IPv4 raspberrypi                                   SSH Remote Terminal  local
+   eth0 IPv4 raspberrypi [b8:27:eb:a8:33:03]               Workstation          local
Although I only see local services (and there are others that I can see on my Mac).
On my Mac I can't see it (with Bonjour Browser.app) or resolve:
⌘ ping raspberrypi.local
ping: cannot resolve raspberrypi.local: Unknown host
The other way around does not work either:
$ ping Tino.local
ping: unknown host Tino.local
They are on the same network (192.168.178.x) and I can ssh into the pi and back into my mac. I have rebooted multiple times already.
What next steps can I take?
Tino
  • 253
In case someone else stumbles upon this, this might be useful:
  • you could try avahi-resolve to see if it's a problem with the NSS integration or the actual hostname resolution
  • try a tcpdump -i wlan0 port 5353 or igmp -w /tmp/mdns.pcap (IGMP) and wireshark /tmp/mdns.pcap (should work from both the pi and your laptop) to inspect what's sent over the wire and see who's not doing what they are supposed to
Better late than never ...
You can check the name used by using service or systemctl
alexis@Oreo:~$ sudo systemctl status avahi-daemon
[sudo] password for alexis:
● avahi-daemon.service - Avahi mDNS/DNS-SD Stack
   Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor pre
   Active: active (running) since Wed 2021-02-03 08:33:50 CET; 5h 50min ago
 Main PID: 1692 (avahi-daemon)
   Status: "avahi-daemon 0.7 starting up."
    Tasks: 2 (limit: 4915)
   CGroup: /system.slice/avahi-daemon.service
           ├─1692 avahi-daemon: running [Oreo.local]
           └─1708 avahi-daemon: chroot helper
You can fix it by editing /etc/avahi/avahi-daemon.conf and rebooting (or restarting the service)
[server]
host-name=the_hostname
domain-name=local
As libnss_mdns communicates with avahi-daemon via UNIX-domain socket, strace helps (as it always does :) In my case it discovered wrong permissions on /run/avahi-daemon:
$ ping example
ping: unknown host
$ getent hosts example.local
(no answer)
$ strace -ff -tt -s4096 -ostrace.out getent hosts example.local
$ less strace.out*
00:19:07.361257 connect(3, {sa_family=AF_UNIX, sun_path="/var/run/avahi-daemon/socket"}, 110) = -1 EACCES (Permission denied)
$ ls -ld /run/avahi-daemon/
drwx------ 2 avahi avahi 80 Dec  9 23:25 /run/avahi-daemon//
$ sudo chmod 755 /run/avahi-daemon/
192.168.1.11    example.local
sizif
  • 101
Try them on the same network hub, not going through a router. Thus, both on the same line out of your router, then they might be able to hear each other.
anon
