I started out with a 2GB SD card, but I'm finding this a bit cosy, so I've bought a 16GB card to replace it. With a single Pi, can I transfer all my work between the cards, or do I need to start from scratch?
Asked
Active
Viewed 1.7k times
23
You should be able to copy the image, using the same application you flashed it with (or the dd command in Linux):
dd if=/dev/sdx of=/path/to/image
Where sdx represents the SD card.
This can then be flashed onto the new SD card just like the original one:
dd if=/path/to/image of=/dev/sdx
For more information, see this question:
How do I backup my Raspberry Pi?
And you can see how to increase the size of the image here:
There is an app pre-installed with raspbian that can copy the whole sdcard into a new sdcard through USB. The name of the app is sd card copier. It can be found in accessories.
Sohan Arafat
- 1,852
- 2
- 12
- 43
