I want to run some script at bootup, right now I'm trying to see if can achieve this using rc.local is this even a good practice??
To try out this script that it's supposed to run at bootup I'm am trying to run it just with the default code that comes within the scriptThe one that prints the IP address). The problem is that when I run this script manually it works perfectly even if I put some other scripts and I run this one everything seems okay the problem is at bootup it doesn't work.
I'm trying to fix this and after two days of research I've learned some things if reboot the pi and run :
sudo systemctl status rc-local
there are errors and the console displays that the operation has failed in red letters because of some compatibility error. Is there a problem with the OS? I'm using the latest version of raspian (STRECH).
rc-local.service - /etc/rc.local Compatibility
   Loaded: loaded (/lib/systemd/system/rc-local.service; static)
   Active: failed (Result: exit-code) since Mon 2016-01-25 18:16:55 CET; 3min 49s ago
  Process: 378 ExecStart=/etc/rc.local start (code=exited, status=203/EXEC)
Jan 25 18:16:55 pocketvj-100 systemd[1]: rc-local.service: control process exited, code=exited status=203
Jan 25 18:16:55 pocketvj-100 systemd[1]: Failed to start /etc/rc.local Compatibility.
Jan 25 18:16:55 pocketvj-100 systemd[1]: Unit rc-local.service entered failed state.
Also, I got the warning that suggests us to run:
sudo systemctl daemon-reload
so I did it and it didn't work out for me.
I also verified if this script was even executable and it was, using
ls -l
I got this:
 -rwxr-xr-x
and as far as I know, this is okay.
  • Is this compatibility error possible to fix?
  • rc.local good practice?
  • Should I better try systemd workaround or crontab?
  • what are the best practices?
Ingo
  • 42,961
  • 207
Yes, and it is probably the simplest and easiest one. It is, however, not completely foolproof.
That default is a peculiarity of Raspbian and has been there for a long time. I'm not quite sure what the point of it ever was because something printed to console during boot is very hard to catch, and impossible if you are using a graphical boot.
Something to note here is that this won't happen if the system hasn't gotten an IP address yet:
_IP=$(hostname -I) || true
if [ "$_IP" ];
The essentially pointless || true may obfuscate that (it just sets the exit status to 0, which it would have been anyway since there is an explicit exit 0 here too); in any case it is possible (or most probable) that the test will fail because there is no IP address to print.
I think you are misinterpreting this line:
This is just referring to the service itself. The rc.local file is really a relic of SysV init, and systemd's rc-local.service implements compatibility with it's traditional use.
A little bit of searching online implies the 203/EXEC status means the script did not run because:
  • It is not executable (but you seem to have ruled this out).
  • The shebang is messed up; this is the first line that should be #!/sh -e (it could be other things too but that is the default). A possibility is that editing it on a Windows machine screwed up the line endings, which are significant there.
    A somewhat more robust shebang is #!/usr/bin/env bash. See if that helps.
Because it runs from the command line does not mean it will fly via init. For starters, whatever you are doing should not remain in the foreground for more than a second or two. It also should not require a GUI context, and should not make much (really, any, contra the Rasbpian "print IP") use of the standard output or error stream.
Debian like most other distributions has decided to replace the old style SysV init system with systemd because it fits better to modern multi core / multi processor machines. This way systemd comes also to Raspbian since Raspian Jessie. Because this is the upcoming system I have decided for me to use it consequent. So I would answer your questions:
As @goldilocks already stated this is only the name of the systemd unit that emulates old style SysV behaviour for compatibility.
rc.local is emulated by systemd. I believe it is less error prone to use the original than the emulation. You just make the experience.
systemd isn't a workaround. Things are made by systemd. All others are workarounds.
That is your decision. I will give you an example to start your program with a systemd unit.
Create a new systemd unit with:
rpi ~$ sudo systemctl --force --full edit thonny.service
In the editor insert these statements, save it and quit the editor:
[Unit]
Description=Service to start thonny
Wants=graphical.target
After=graphical.target
[Service]
User=pi     # or must it run as root? Then omit this line
ExecStart=/home/pi/thonny   # or where your program is
[Install]
WantedBy=graphical.target
Enable the new service:
rpi ~$ sudo systemctl enable thonny.service
reboot.
Check with:
rpi ~$ systemctl status thonny.service
rpi ~$ systemctl cat thonny.service
Edit again with:
rpi ~$ sudo systemctl --full edit thonny.service
I don't know if it runs on the first attempt. There may be some edge conditions I don't know, something like user rights, environment etc. It is no problem to configure these dependencies. The problem is to find them ;-)
Ingo
  • 42,961
  • 207
I usually don't mess with services, init, or anything like that. I simply place a cron entry that runs at boot.
