Problem:
I have a Raspi 3B rev: a02082 (Q1 2016 3 Model B 1.2 1 GB (Mfg by Sony)) running raspbian jessie kernel 4.9.35-v7
I want to signal to a power management circuit that filesystems have been un-mounted and now we can remove the power from the raspberry pi.
The
dtoverlay=gpio-poweroff,active_low=y
option when set in /boot/cmdline.txt is supposed to drive GPIO26 low after shutdown.
However, watching the pin on a scope, it stays at 0 volt irrespective of the state of the Pi (booted/shutdown)
I have tried changing the pin numbers in the dtoverlay=gpio-poweroff parameters, also I have tried with and without the active_low option.
The GPIO pin is functional - because if I test with: echo "26" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio26/direction echo "1" > /sys/class/gpio/gpio26/value I can see the pin go high on the oscilloscope.
Questions
  • 1: Why might it not be working?
  • 2: How can we debug the overlay?
  • 3: Should we expect a spike/edge on the pin by the overlay on shutdown - or a continuous low/high?
saraf
  • 571
It MIGHT have something to do with:-
    active_low              Set if the power control device requires a
                            high->low transition to trigger a power-down.
                            Note that this will require the support of a
                            custom dt-blob.bin to prevent a power-down
                            during the boot process, and that a reboot
                            will also cause the pin to go low.
Frankly I have never been able to make head nor tail of this cryptic "documentation", but it works perfectly on my Pi without using this parameter.
I have had both of these work to force pin 17 low after shutdown. Not sure if this will work for your situation or with any other pins.
option 1. edit /boot/config.txt add this
dtoverlay=gpio-poweroff,gpiopin=17,active_low=1
option 2 run this from command line
sudo dtoverlay -v gpio-poweroff gpiopin=17 active_low=1
don bright
  • 101
