I'm trying to set up a Raspberry Pi Zero W as a headless device on my local network, and am performing the initial setup with a fresh copy of Raspbian Stretch
I've tried installing both the latest Raspbian Stretch lite and the latest Raspbian Stretch with desktop, and was able to get it set up for SSH by configuring the wpa_supplicant.conf file with WiFi credentials and creating an empty ssh file.
I've tried SSH'ing in from multiple different computers, and the problem is the same every time. I log in with pi@192.168.0.102, which I've confirmed to be the devices' IP Address. It asks for the password, so I type raspberry, as per the online guides. It does not accept it. It will repeat the password: field 3 times, then ask for pi@192.168.0.102's password:.
At this point, I get "Permission denied, please try again". I get the same password query again, and upon entering it:
Received disconnect from 192.168.0.102 port 22:2: Too many authentication failures.
Authentication failed
Adding -v for debug just shows it trying all my local private keys in my .ssh folder, which are for something else (so they don't work of course) and eventually falling back to publickey,password,keyboard-interactive, where it asks for the password again.
I am absolutely certain that raspberry is the correct password, as multiple online sources have confirmed it, and I am certain I've type it correctly (I even had a friend type it for me to no avail).
What's going on here?
Edit: I've tried from MacOS, Windows, and Android (Termux with OpenSSH installed), and I've tried connecting over USB instead of WiFi. The issue persists. Maybe there is some way to generate an SSH key for the pi? (I don't have a Mini HDMI converter so the GUI is not accessible)
Edit2: I was able to get into the terminal via USB OTG, and the default password worked. I changed the password. After some tinkering around (I'm not entirely sure what changed), I was able to SSH in via an emulated Ethernet over USB as pi@raspberrypi.local. That means my real issue is with connecting to the WiFi - something I've already spent 2 hours trying to get work while connected with g_serial.
Edit3: I decided my best course of action was to try and set up a VNC server on the Pi. I was able to successfully share my internet from my work MacBook and SSH in. However, I'm getting errors while running sudo apt-get install tightvncserver:
Err:41 http://mirrordirector.raspbian.org/raspbian stretch/main armhf tightvncserver armhf 1:1.3.9-9
Cannot initiate the connection to mirrordirector.raspbian.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 2a00:1098:0:80:1000:75:0:3 80]
ifconfig for the USB ethernet connection returns this:
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.3 netmask 255.255.255.0 broadcast 192.168.2.255
inet6 fe80::f87c:94fd:7b3e:454d prefixlen 64 scopeid 0x20<link>
ether 4e:38:f5:71:6e:74 txqueuelen 1000 (Ethernet)
RX packets 2080 bytes 214353 (209.3 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1935 bytes 348268 (340.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Pinging mirrordirector.raspbian.org
ping mirrordirector.raspbian.org
PING mirrordirector.raspbian.org (93.93.128.193) 56(84) bytes of data.
^C
--- mirrordirector.raspbian.org ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4151ms
