I was trying to setup a ssh connection to my pi 2 (model B, i.e., no inbuilt wifi) in headless mode from my ubuntu machine. I do not have a router. After multiple attempts of flashing and tweaking, the following worked,
  1. Add ssh file in /boot
  2. Uncommenting the following lines in /etc/dhcpcd.conf
profile static_eth0
static ip_address=192.168.1.23/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
interface eth0 fallback static_eth0
After this it asks for
pi@192.168.1.23's password:
to which i supplied the default password for rpi
raspberry
but it keeps saying Permission denied, please try again.for three times after which it closes the connection. I tried this and this, but it would not work. Note that I do not have a windows machine or a hdmi-in enabled screen. I don't remember having this problem in earlier versions of raspbian. I am using 2018-11-13-raspbian-stretch-full.img.
REVOLUTION
  • 61
When I did,
$ssh pi@192.168.1.23
after making my IP static, pi gave the following,
Which was misleading, as no user 192.168.1.23 exists. Hence it kept showing Permission Denied. It would ask passwords for this user, even when I had disabled passwords.
Finally, after restarting my computer and re-flashing the OS on the SD card, I was able to get it working without static IP. And the standard command worked,
$ssh pi@raspberrypi.local
I figured that DHCP must have been misbehaving on my computer as I kept switching my ethernet port from RPI to LAN. After restarting it must have got reset.
REVOLUTION
  • 61
No more default pi user with raspberry password.
https://www.raspberrypi.com/news/raspberry-pi-bullseye-update-april-2022/
