I have made some tests with a temperature sensor tmp102 connected with 1m long cables and it works great. Now I am wondering if I can use a 10m long cable and if yes, what type of cable shall I use? I've read that i2c bus was originaly designed for shord distance.
Asked
Active
Viewed 9,428 times
This should help you: AN10658 Sending I2C-bus signals via long communications cables
If possible you should use a cable with the lowest capacitance, maybe Cat5 cable or something closer. Shielding won't hurt either.
The maximum I2C cable capacitance is limited to 500pf, a cat5 cable has the capacitance of 50pf/meter. So, basically, for a 10m cable you will be fine if you use 100kHz standard transmission mode. For longer cables you might need to lower your transmission speed, people on the net talk about 100m length clocked at 500Hz.
lenik
- 11,533
- 2
- 32
- 37
