RPi 1 Model A here. Brand new to RPi and electronics in general. I'm finding a hard time finding the exact voltage/current "ratings" for my model but the closest I could find was a comment under this question here where the comment reads:
"The 8ma and 16ma figures refer to pins configured for output. 0.5ma is for pins configured for input. Just ensure that there's always at least (Vss * 2Kohm) resistance between Vss and the pin then no more than 0.5ma can ever flow in to the input."
So from this comment, as well as other articles I've collected, my understanding of how my specific model of RPi outputs voltage & current is as follows:
  • There is a difference in voltage/current output depending on whether we're talking about input GPIO pins, or output GPIO pins
  • For input GPIO pins, my RPi expects 3.3V and 0.5mA coming into it from a breadboard or any other connected components (LEDs, pushbuttons, etc.)
  • For output GPIO pins, my RPi expects 3.3V and between 8mA and 16mA (safely) coming out of it (and into a breadboard or any other connected components)
Can someone confirm/clarify my understanding for me? I want to make sure I don't "fry my pi" by giving it too much voltage and/or current to a specific pin!
smeeb
  • 645
  • 22
Lets first define what a input vs a output is.
Input is measuring if there is any voltage coming in or not on the GPIO pin.
Output is driving a load to either to a high voltage, 3.3V or zero voltage. The load can be maximum 16mA.
So when you measure (input) a voltage on a GPIO the only thing you have to consider is not to exceed 3.3 volt, the current is decided by the GPIO's internal resistance.
Ref.: Section 6, https://www.raspberrypi.org/documentation/hardware/computemodule/RPI-CM-DATASHEET-V1_0.pdf
MatsK
  • 2,882
  • 22
The GPIO hardware peripheral is identical on all current Pi models.
The GPIO are all 3V3. This means you should not expose them to a voltage outside the range 0 to 3.3V.
When set as an input the GPIO will be seen as a very high resistance. It will only use a few microamps to register as low or high.
When set as an output the current you can draw whilst ensuring that the output will be reliably low or high depends on the (configurable) drive strength which defaults to 8mA. This means that if you set the GPIO as an output and write 1 the GPIO may appear to be at a logic 0 if you draw more than 8mA.
joan
  • 71,852
  • 76
  • 108
