10
I am not able to ssh into my pi. RPI is connected directly to my host PC.
I have set IP address of my host :----
sudo ifconfig eth0 192.168.0.204 netmask 255.255.255.0 up
sudo route add default gw 192.168.0.200
Pi have default IP in network interfaces file as :----
auto lo eth0
iface lo inet loopback
iface eth0 inet static
    address 192.168.0.202
    gateway 192.168.0.200
if config comand on my PC :-----
ignite@ignite-desktop:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 6c:f0:49:f3:a6:1b
          inet addr:192.168.0.204  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::6ef0:49ff:fef3:a61b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:681 errors:0 dropped:0 overruns:0 frame:0
          TX packets:208 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:43752 (43.7 KB)  TX bytes:33407 (33.4 KB)
          Interrupt:26 Base address:0x4000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1012 (1.0 KB)  TX bytes:1012 (1.0 KB)
Ping is working for same host :----
ignite@ignite-desktop:~$ ping 192.168.0.204
PING 192.168.0.204 (192.168.0.204) 56(84) bytes of data.
64 bytes from 192.168.0.204: icmp_seq=1 ttl=64 time=0.026 ms
64 bytes from 192.168.0.204: icmp_seq=2 ttl=64 time=0.018 ms
64 bytes from 192.168.0.204: icmp_seq=3 ttl=64 time=0.017 ms
64 bytes from 192.168.0.204: icmp_seq=4 ttl=64 time=0.014 ms
Ping is working for pi from my host PC :----
ignite@ignite-desktop:~$ ping 192.168.0.202
PING 192.168.0.202 (192.168.0.202) 56(84) bytes of data.
64 bytes from 192.168.0.202: icmp_seq=1 ttl=64 time=0.530 ms
64 bytes from 192.168.0.202: icmp_seq=2 ttl=64 time=0.508 ms
64 bytes from 192.168.0.202: icmp_seq=3 ttl=64 time=0.464 ms
64 bytes from 192.168.0.202: icmp_seq=4 ttl=64 time=0.445 ms
64 bytes from 192.168.0.202: icmp_seq=5 ttl=64 time=0.434 ms
SSH is not working
ignite@ignite-desktop:~$ ssh pi@raspberrypi
ssh: Could not resolve hostname raspberrypi: Name or service not known
ignite@ignite-desktop:~$ ssh pi@192.168.0.202
Read from socket failed: Connection reset by peer
ignite@ignite-desktop:~$ ssh 192.168.0.202 -l pi
Please suggest how to resolve it ?
edit :---
ssh -vvv pi@192.168.0.202 ---> output is
ignite@ignite-desktop:~$ ssh -vvv pi@192.168.0.202
OpenSSH_5.1p1 Debian-6ubuntu2, OpenSSL 0.9.8g 19 Oct 2007
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.0.202 [192.168.0.202] port 22.
debug1: Connection established.
debug1: identity file /home/ignite/.ssh/identity type -1
debug1: identity file /home/ignite/.ssh/id_rsa type -1
debug1: identity file /home/ignite/.ssh/id_dsa type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-2
debug1: match: OpenSSH_6.0p1 Debian-2 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.1p1 Debian-6ubuntu2
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
Allan
  • 201
6 Answers6
I had same issue with newly installed raspbian and the problem was with server side ssh host keys.
These keys are not generated on image for the reasons that each device must have different ssh keys and during first boot are these keys generated automatically.
My problem was that probably during generating these keys I disconnect supply, they was wrong with zero size.
Solution is to regenerate ssh server side host keys:
rm /etc/ssh/ssh_host_*
dpkg-reconfigure openssh-server
https://wiki.debian.org/SSH#Regenerating_host_keys
vlk
  • 301
Reason for issue and fix
Without special programs, you cannot ssh into the Pi using its host name. For LAN networks, ping the host. Once you have the IP, write it down. Then write into the terminal:
ssh pi@this_is_the_ip
and you should be able to log in.
If you want to access the Pi from outside of your home network, you must port forward your router. In fact, there is a stack exchange question on how to do this.
Assuming that you still want to use a nice name for your Pi, there is one option that will work both within your network and without it.
DNSDynamic
This software allows you to set up a domain name for your pi.
  1. Go to their website and set up a domain name and an account.
  2. Install ddclient on your Pi.
    sudo apt-get install ddclient
    And then edit the config settings.
    sudo nano /etc/ddclient.conf
    Finally, change the file to the following:
# /etc/ddclient.conf
daemon=600
timeout=10
ssl=yes
protocol=dyndns2
use=web, web=myip.dnsdynamic.com #Enter your URL here
server=www.dnsdynamic.org
login=x@gmail.com  #userid for dnsdynamic.com
password='xxxx'      #password for the same put inside quotes
x.dnsdynamic.com  #the domain name you created
Assuming that you want this to auto start every time your computer wakes up, enter the following into the terminal.
sudo nano /etc/rc.local
Add the following command before exit 0(which is the last line)
sudo /usr/sbin/ddclient -daemon 600 -syslog
Lastly, you must still portforward.
Hopefully this is helpful. Ask questions in the comment section below.
xxmbabanexx
  • 3,278
  • 36
  • 56
You can have a look at my answer for this questions.
How to get the Raspberry Pi's IP address for SSH
Another possibility I didn't mention there is to buy a domain (it's very cheap) and play with the DNS. I bought the domain aasgard.info for 0.99 cents and assigned name ygdrasill.aasgard.info to an internal address (192.168.1.141 in this case). Then you need to set the default domain as the domain name you bought and voila' :)
I must confess that after having spent all the time to set up the domain I realized that using /etc/hosts file or avahi was much much easier :)
Remo.D
  • 544
Are you sure that you've started an SSH server on your Raspberry Pi? Just because you can ping it doesn't mean it's running an SSH server. Try sshd for a light SSH server.
user1945104
  • 123
Enable SSH
As of the November 2016 release, Raspbian has the SSH server disabled by default.
It can be enabled manually from Terminal:
sudo raspi-config
Select Interfacing Options
Navigate to and select SSH
Choose Yes
Select Ok
Choose Finish
or
Launch Raspberry Pi Configuration from the Preferences menu
Navigate to the Interfaces tab
Select Enabled next to SSH
Click OK
Alternatively, use systemctl to start the service
sudo systemctl enable ssh
sudo systemctl start ssh
SDsolar
  • 2,378
  • 26
  • 43
Noufal
The SSH connectivity is by default DISABLED in latest raspberry pi. The RPi which are released in/after November 2016.
The steps are: 1) Write raspbian image to SD card. 2) create a ssh file without extension. 3) copy that ssh file to SD card where your image is written. 4) Finally wou will be able to SSH your raspberry pi.
For more details watch this video : https://www.youtube.com/watch?v=zKT6bTESlLs
