77
There are 5 LEDs on the RPi: OK, PWR, FDX, LNK, 10M.
I'd like to know if it's possible to control any of these from software i.e. turn them on, or change intensity (or even change colour gasp).
And if so, where can I read up about it? The LEDs could be quite handy way of signalling user application status when they are not required for the original use.
darryn.ten
  • 1,476
Maria Zverina
  • 5,188
7 Answers7
65
The OK LED can be controlled from user space software. Details here: Re: Can we control the on-board leds
Summarised from the above (all credit to BrianW):
The OK LED is available as /sys/class/leds/led0/.
The kernel LED driver has "triggers" which let some other part of the kernel control the LED. The default trigger for the LED is 'mmc0', which makes it come on when the SD card is accessed.
root@raspberrypi:~# cat /sys/class/leds/led0/trigger
none [mmc0]
You can deactivate the mmc0 trigger as follows:
echo none >/sys/class/leds/led0/trigger
The LED can be turned on and off using the 'brightness' file. The minimum brightness is 0, and the maximum is 255. As there is no variable brightness support, any value greater than 0 will turn the LED on.
echo 1 >/sys/class/leds/led0/brightness
echo 0 >/sys/class/leds/led0/brightness
Setting the brightness to 0 automatically sets the trigger to "none".
If you want the LED to go back to its default function:
echo mmc0 >/sys/class/leds/led0/trigger
There are a couple of kernel modules you can load up (ledtrig_timer and ledtrig_heartbeat) which will flash the LED for you.
modprobe ledtrig_heartbeat
echo heartbeat >/sys/class/leds/led0/trigger
Once you have turned off the mmc0 trigger, you can use GPIO16 to control the LED. It's active-low, so you need to set the pin low to turn the LED on, and high to turn it off.
From Python, you can use the module RPi.GPIO to control pin 16. There is also a C# driver.
Sample code
#!/usr/bin/python
import RPi.GPIO as GPIO from time import sleep
Needs to be BCM. GPIO.BOARD lets you address GPIO ports by periperal
connector pin number, and the LED GPIO isn't on the connector
GPIO.setmode(GPIO.BCM)
set up GPIO output channel
GPIO.setup(16, GPIO.OUT)
On
GPIO.output(16, GPIO.LOW)
Wait a bit
sleep(10)
Off
GPIO.output(16, GPIO.HIGH)
Guy
  • 1,667
None of the on board LEDs can be controlled in software - they are all used for other things.
  • OK - indicates SD card access
  • PWR - indicates power to the micro USB connection
  • FDX - Full Duplex LAN
  • LNK - LAN Activity
  • 10M - 10M/100M connection speed - if it is lit, the RPi is connected at 100M.
Now, that's the official answer... Let's study the schematic.
Page 4 The PWR LED is connected directly to the power supply, so we can't control that in software.
Page 3 FDX, LNK and 10M are all connected to the Ethernet chip, so again we can't control them in software (without some funky traffic hack...).
Page 4 BUT OK is actually controlled by GPIO 16, so there is the possibility of a hack...
Alex Chamberlain
  • 15,638
You can control all leds (except PWR in older Pi models, as said in other answers).
But for ethernet leds you will need to patch the driver and recompile the kernel.
Information of how recompile can get here: http://elinux.org/RPi_Kernel_Compilation
Patch and more information here(google translate if need): http://everpi.tsar.in/2013/11/patch-para-controlar-os-leds-ethernet-do-raspberrypi.html
After done, you be able to control over: /sys/class/smsc95xx_leds and eth_fdx, eth_lnk e eth_spd.
Example: echo 0 > /sys/class/smsc95xx_leds/eth_fdx echo 1 > /sys/class/smsc95xx_leds/eth_fdx
Bex
  • 2,929
  • 26
  • 34
czar
  • 91
I can confirm that with the Raspberry Pi 2 it's possible to control the PWD LED as well!
The power LED is controlled by the files in:
/sys/class/leds/led1
You can turn it off just like the Status LED using:
echo 0 > /sys/class/leds/led1/brightness # Power LED
echo 0 > /sys/class/leds/led0/brightness # Status LED
See Guy's answer for more ways to control the LEDs
Bex
  • 2,929
  • 26
  • 34
Patrick
  • 181
I wrote a userspace program which let you control the Ethernet LEDs.
The program requires the more recent libusb-1.0 (NOT the older 0.1). It works with LAN9512 (e.g. on the older Raspberry B) as well as LAN9514 chips (e.g. on Raspberry B+ or Raspberry 2)
Details can be found here: LAN951x LED control
Jackfritt
blip
  • 81
There is a simpler way to control the LAN LEDs from userland. Source code is available from
http://www.raspberrypi.org/forums/viewtopic.php?f=63&t=72070
The program needs to be run with sudo.
joan
  • 71,852
  • 76
  • 108
With the Pi 2, you can control both the red and green onboard LED's.
The Windows 10 IoT documentation lists the red power LED and the green Ok LED on GPIO 35 and 47, respectively.
https://ms-iot.github.io/content/en-US/win10/samples/PinMappingsRPi2.htm
I tried with the Windows 10 IoT and with Python on Raspbian. Both can control the LED's, although Raspbian does override the LED whenever something accesses the SD card. Presumably, clearing the trigger would remove this behavior.)
Here's a sample. (Note that this does not override the trigger as mentioned in prior posts)
print ("Program Start")
import time
channels = [35, 47]
print ("Turning off LED's")
GPIO.setup(channels, GPIO.OUT)
GPIO.output(channels, GPIO.LOW)
time.sleep(5)
print ("Turning on LED's")
GPIO.output(channels, GPIO.HIGH)
time.sleep(5)
GPIO.cleanup()
print ("Program End")
TomXP411
  • 151
