I was playing with the raspberry pi leds (How do I control the system LEDs using my software?)
Interestingly, on my pi the following command fails:
sudo echo heartbeat >/sys/class/leds/led0/trigger
The error is bash: /sys/class/leds/led0/trigger: Permission denied
However if I run the following pair of commands things work:
sudo -s
I would have thought the two ways of triggering the LEDs are the same. Are there some things sudo cannot do?
John Smith
  • 1,251
The shell interprets and handles redirection before the command is executed. So the redirection (>/sys/class/leds/led0/trigger) is attempted with the user's permissions, thus fails.
The generally recognized solution is to use the tee command: (man page and wikipedia)
echo heartbeat | sudo tee /sys/class/leds/led0/trigger >/dev/null
The tee command splits (tees!) its input into two streams, one going to a file specified on the command line, the other to stdout. In this example, I've used the ability to specify a filename to write to that file with sudo privileges, and discard the duplicate output going to stdout.
lornix
  • 1,066
As explained by lornix it's because the shell handles redirection before the command is executed.
I prefer this type of invocation
sudo sh -c "echo 4 >/sys/class/gpio/export"
In your case
would become
sudo sh -c "echo heartbeat >/sys/class/leds/led0/trigger"
joan
  • 71,852
  • 76
  • 108
