On a clean install of Raspbian Jessie I want to play mp3s via mplayer through my Sabrent USB Audio driver. On Raspbian itself this was plug n' play; I changed the default audio device to "USB Audio Device" and then Youtube etc. worked as desired. In the CLI,
mplayer myfile.mp3
also worked perfectly. But in Python (3.4), the audio keeps funneling through HDMI to my monitor's speakers. This happens even when I switch my Python mp3 player to pygame, so it seems to be an issue with RasPi settings / Python.
Edit: When I changed the default audio device, I did so through the Jessie desktop interface in Preferences / Audio Device Settings. That window lists "USB Audio Device (Alsa mixer)" as default, as desired.
Twiffy
  • 141
As pygame rely on SDL system, we have to define the audio driver for SDL. This can be done with environnement variables.
You can define it in your python script, but this must be done before you init pygame.
os.putenv('SDL_AUDIODRIVER', 'alsa')
os.putenv('SDL_AUDIODEV', '/dev/audio')
You may also define the env.var. SDL_AUDIODEV in the same manner, if you know the /dev/ node of your sound card. The value of this variable should look like "/dev/audio" "/dev/snd".
Technico.top
  • 1,426
The problem wasn't anything to do with Python, but rather that my pi user settings were different from my root user settings, so that the former went through the chosen USB audio device, but I couldn't get the latter to change from default settings. I only noticed this via Python because I would run my python script using sudo.
The non-accepted answer from this thread did the trick! To recap here:
1) Get a list of your sound cards using aplay -l
2) Create/edit the system-wide alsa configuration file at /etc/asound.conf, e.g. with sudo nano /etc/asound.conf
3) Into this file, paste
pcm.!default {
    type hw
    card 0
ctl.!default {
    type hw
    card 0
except use whatever the desired card number is. In my case this was card 1.
Twiffy
  • 141
