I'm following Simple guide for setting up OTG modes on the Raspberry Pi Zero, the fast way!
What I've done;
  1. flashed latest (2017-04-10) Raspbian image onto SD card,
  2. added dtoverlay=dwc2 on new line to config.txt
  3. created blank ssh file (without any extension) on ./boot partition,
  4. modified cmdline.txt file, by adding modules-load=dwc2,g_ether right after rootwait,
  5. booted Raspberry Pi Zero, waited for 90 seconds and tried to ssh pi@raspberrypi.local using ssh openssh client with Linux and PuTTY on Windows (Pi connected to PC using USB cable).
There was NO other changes made to SD card, other then what I mentioned above.
I'm able to ssh in from MacOS & Windows, but not from Linux:
$ ssh -v pi@raspberrypi.local
OpenSSH_6.6.1, OpenSSL 1.0.1e-fips 11 Feb 2013
debug1: Reading configuration data /home/alexus/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 56: Applying options for *
ssh: Could not resolve hostname raspberrypi.local: Name or service not known
What am I missing?
$ ssh -V
OpenSSH_6.6.1p1, OpenSSL 1.0.1e-fips 11 Feb 2013
$ systemctl status avahi-daemon.service | grep Active
   Active: active (running) since Tue 2017-04-25 12:04:30 EDT; 2h 14min ago
$ grep ^hosts /etc/nsswitch.conf
hosts:      files mdns4_minimal [NOTFOUND=return] dns myhostname
$ avahi-browse --all --domain=local --verbose --terminate | grep -vE '(eno1|docker0|virbr0)'
Server version: avahi 0.6.31; Host name: X.local
E Ifce Prot Name                                          Type                 Domain
: Cache exhausted
: All for now
Please advise.
* UPDATE *
NSSWITCH.CONF(5):
hosts:      files mdns_minimal dns mdns myhostname
avahi-daemon.conf(5):
$ grep ^use-ipv /etc/avahi/avahi-daemon.conf
use-ipv4=yes
use-ipv6=yes
use-ipv6=yes is disabled by default. I un-comment that line followed by restart of avahi-daemon.socket & avahi-daemon.service, I now sometimes able to see following:
$ avahi-browse --all --domain=local | grep -vE '(docker0|virbr0|eno1)'
+ enp0s20u8 IPv6 raspberrypi [XX:XX:XX:XX:XX:XX]               Workstation          local
- enp0s20u8 IPv6 raspberrypi [XX:XX:XX:XX:XX:XX]               Workstation          local
per output above, raspberrypi entry comes and goes
avahi-daemon@Linux:
May  5 10:42:10 wcmisdlin02 avahi-daemon[8336]: Joining mDNS multicast group on interface enp0s20u7.IPv6 with address fe80::150b:ff04:b4e9:692e.
May  5 10:42:10 wcmisdlin02 avahi-daemon[8336]: New relevant interface enp0s20u7.IPv6 for mDNS.
May  5 10:42:10 wcmisdlin02 avahi-daemon[8336]: Registering new address record for fe80::150b:ff04:b4e9:692e on enp0s20u7.*.
May  5 10:42:54 wcmisdlin02 avahi-daemon[8336]: Withdrawing address record for fe80::150b:ff04:b4e9:692e on enp0s20u7.
May  5 10:42:54 wcmisdlin02 avahi-daemon[8336]: Leaving mDNS multicast group on interface enp0s20u7.IPv6 with address fe80::150b:ff04:b4e9:692e.
May  5 10:42:54 wcmisdlin02 avahi-daemon[8336]: Interface enp0s20u7.IPv6 no longer relevant for mDNS.
- enp0s20u7 IPv6 raspberrypi [XX:XX:XX:XX:XX:XX] Workstation local:
+ enp0s20u7 IPv6 raspberrypi [XX:XX:XX:XX:XX:XX] Workstation local:
debug1: Connecting to raspberrypi.local [fe80::e0e0:f91:8e3:73b3] port 22.
debug1: connect to address fe80::e0e0:f91:8e3:73b3 port 22: Invalid argument
ssh: connect to host raspberrypi.local port 22: Invalid argument
$ ssh -6 pi@fe80::e0e0:f91:8e3:73b3%enp0s20u7 uname -a
Linux raspberrypi 4.4.50+ #970 Mon Feb 20 19:12:50 GMT 2017 armv6l GNU/Linux
alexus
  • 337
  • 25
I understand this question is quite old, and perhaps resolved in some way other than posted. However, I've posted an answer to a similar question on the Unix and Linux StackExchange.
The short answer is that the GNU/Linux host Pc's Ethernet port needs to be setup with a network bridge through Network Manager's commandline tool nmcli. And then the Pi's OTG Network interface needs to be added to that bridge. Your DHCP server should then give your Pi an IP address through the GNU/Linux host PC bridged ethernet port.
Here's the longer answer:
How to setup Networking via Network Manager's nmcli for a Raspberry Pi connected to a host PC via the USB port running in OTG mode.
Hopefully this helps, if you still need help.
RubberStamp
  • 1,449
When using RNDIS to connect to a Linux host machine, the biggest pitfall (compared to the procedure with Mac/Windows) may be that you need to switch the connection method under IPv4 Settings to Link-Local Only instead of Automatic.
There's some mention of that in this other question and here too.
Otherwise, this works out of the box for me connecting a Raspbian 8 device with g_ether to an Ubuntu 16.04 desktop.
Well, it works for connecting one time. Another pitfall specific to Linux is that NetworkManager creates a new connection entry each time.
Could you confirm if you've already attempted configuring Link-Local Only? If the problem persists, please specify your host Linux distro (apparently it's something older with OpenSSH 6) to help narrow down. There is probably a lot else that could go wrong depending on interplay between Avahi, NetworkManager, and all things USB/ethernet.
jdonald
  • 2,972
  • 39
To me the "Could not resolve host name raspberrypi.local" would indicate that there is not any ip address connected to that hostname. You could try to use the ip address. If the ip address is static, that would be easy. If it changes, you could try a ping script to locate it. See question/answer Unable to resolve IP address for RPi connected through ethernet.
pi@RPi3:~ $ for x in $(seq 2 20); do ping -rc1 -W1 192.168.0.$x | grep 'from'; done
bstipe
  • 574
