I am going to be staying in a hotel in the future, and I need to be able to use Ethernet devices there. The hotel provides free WiFi, however it has no way of providing Ethernet.
I have the idea of connecting to the free WiFi using a Raspberry Pi, and then pushing the internet connection out of the Ethernet port on the Pi.
This website seems to explain what I need to do, as does this post.
Everything seems fine here, apart from the bind addresses for the WiFi adapter. I don't know what IP addresses will be available on the WiFi network, and although I could put in a random ip address like 192.168.0.239, I don't know what range the network runs on either. It could be X.X.X.X, for example:
  • 192.168.0.X
  • 192.168.42.X
  • 10.0.2.X
  • 10.0.0.X
How can I make this set-up work without knowing any of the DHCP information beforehand?
Thank you for any responses.
Although it can be done with a Raspberry Pi I'd like to offer the D-Link N300 as an alternative solution. It is a range extender with in-built ethernet. I have this device and it works well for the low cost.
Andy Anderson
  • 649
To find your IP address on RPi, do the following:
In the command line, type:
ping google.com
Then press CTRL-C to stop. This is making sure you have a successful connection.
Now, type:
ip addr
And you should see something like this:
pi@raspberrypi ~ $ ip addr
  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN
  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  inet 127.0.0.1/8 scope host lo
  2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
  link/ether b8:27:eb:8e:b7:42 brd ff:ff:ff:ff:ff:ff
  inet 192.168.1.17/24 brd 192.168.1.255 scope global eth0
pi@raspberrypi ~ $
Your IP address is directly after the second inet (which is below link/ether). In this case, your IP would be 192.168.1.17.
If you want to know the raspberry ip ,all you need to do is: On the Pi
ip a
Or from another device you need an app based on nmap or nmap itself and scan the network,for instance,if the subnet is 192.168.1.xxx , you can type
nmap -F 192.168.1.0/24
and finally,to setup an access point this page may help you.
abaddon s
